Play in Lower Control Arm Ball Joints
Usually you raise the front of the truck off the ground and have someone use a pry bar under the tire to repeatedly lift the tire taking the weight off the lower ball joint while watching for play. There should be ZERO play in a good ball joint.
You have to raise it by the lower control arm or it will not work.
You have to raise it by lower the control arm or it will not work.
Should work at full droop aswell, but raising the LCA will bring it closer to where it normally operates which may show wear differently that at droop.
Prob poor choice of words on my part, yes it will still work but like you said it might not be as effective with the stress on the ball joint at full droop.
Makes sense when you think about it tho, I’ll have to try this in the future should I suspect ball joint issues. I know on my old gmc there was always clunking at full droop as the UCA would hit a metal bump stop to limit travel.
On a side note, I just got my suspension maxx sway bar end links and they look really good. I’ll keep them for when my 2022 has worn out end links.
2019 Ram bighorn, 78000 miles, ball joints still original and tight. I would contact RAMCARES. They helped when my front diff and passenger half shaft started to strip gears, replacement cost $4100.00, they paid all but $300.00 of it and I was at 73000 miles well out of warranty.
I have been in contact with RamCares, they followed up looking for additional info which I provided. Hoping for a response soon.
Just for clarification, I didn't check myself. I had a tire shop and the dealer both tell me it was an issue... the tire shop refusing to do an alignment as a result. The main issue is I'm told my truck will not pass State Inspection, effectively taking my truck off the road.
I really hope it's a mistake some how. Error in the parts schematic or published data that makes it seem like the only way to get a ball joint is with the control arm.
Begs the question, if you're RAM would you design a bespoke ball joint for downstream repair revenue -or- use an off the shelf ball joint that's up to spec to reduce costs?
Ram most likely does not assemble, but simply buys the completed assy from a supplier and simply lists it for sale as such. The aftermarket may offer ball joints to press in, or the arm may be 1 time use only material. Mevotech sure looks good.
Point taken about the supplier. It's a good point actually. Hoping that a press in Ball Joint becomes known.
Mevotech will be the way to go for sure if there's no other way. Really excited to see how they work out for Jeff.
Just so everyone is aware... the OEM control arms are $750 each with 5 hours of labor to do both, with an alignment needed in addition. That pushes the cost to $2,300... and both the dealer and tire shop quoted the same price. Can I get it done marginally cheaper somewhere? Sure. But even $2K is too much in my opinion.
Well I had the Mevotech lowers installed today aaaaaand I am happy to report my front end clunk is finally gone. It was in fact the lower ball joints giving me fits. The front end feels like a new truck again.
Costs:
LT and RT lowers = $406
Install = $305
Alignment = $105
Total = $816
No clunking sound = Pricless
ZERO play isn't true, Ram actually has specs for the lower ball joints. They also have a different procedure than what you claim.
Maybe, and I’m not aware of rams procedure on checking ball joints. This is how I was taught to do it by a very experienced mechanic and has worked well for me. If you can see any movement in the ball joint by eye it’s to much.
Mevotech LCAs...are the ball joints verified to be replaceable?
(Ball joints are a wear item and should be replaced when they exceed tolerance. I am gobsmacked that the Ram LCA does not allow the ball joint to be swapped out.)
The website says it's pressed in so it should be replaceable.
  • Like
Reactions: c3k
It is not that they don't allow it, they don't sell it.
You and me both!
Costs:
Install = $305
Alignment = $105
Total = $816
Really hope these work out great for you, because it's probably the root I have to take as well. Any chance you can post a pic of how they look on your truck?
This is what I've been told as well... some play is built in.
Any idea how much play is "within spec" or how they measure that? Just curious.
