Jeffjad
Here is a video that explains the technique I used. I did not use a gauge but just took video of the ball joint.Can you post a video or explain how you checked the ball joints? Were you just bouncing the front of the truck or?
You have to raise it by the lower control arm or it will not work.Usually you raise the front of the truck off the ground and have someone use a pry bar under the tire to repeatedly lift the tire taking the weight off the lower ball joint while watching for play. There should be ZERO play in a good ball joint.
Should work at full droop aswell, but raising the LCA will bring it closer to where it normally operates which may show wear differently that at droop.You have to raise it by lower the control arm or it will not work.
Prob poor choice of words on my part, yes it will still work but like you said it might not be as effective with the stress on the ball joint at full droop.Should work at full droop aswell, but raising the LCA will bring it closer to where it normally operates which may show wear differently that at droop.
Makes sense when you think about it tho, I’ll have to try this in the future should I suspect ball joint issues. I know on my old gmc there was always clunking at full droop as the UCA would hit a metal bump stop to limit travel.Prob poor choice of words on my part, yes it will still work but like you said it might not be as effective with the stress on the ball joint at full droop.
I have been in contact with RamCares, they followed up looking for additional info which I provided. Hoping for a response soon.2019 Ram bighorn, 78000 miles, ball joints still original and tight. I would contact RAMCARES. They helped when my front diff and passenger half shaft started to strip gears, replacement cost $4100.00, they paid all but $300.00 of it and I was at 73000 miles well out of warranty.
oh... i know.Mevotech is $180/ea.
ZERO play isn't true, Ram actually has specs for the lower ball joints. They also have a different procedure than what you claim.Usually you raise the front of the truck off the ground and have someone use a pry bar under the tire to repeatedly lift the tire taking the weight off the lower ball joint while watching for play. There should be ZERO play in a good ball joint.
Maybe, and I’m not aware of rams procedure on checking ball joints. This is how I was taught to do it by a very experienced mechanic and has worked well for me. If you can see any movement in the ball joint by eye it’s to much.ZERO play isn't true, Ram actually has specs for the lower ball joints. They also have a different procedure than what you claim.
The website says it's pressed in so it should be replaceable.Mevotech LCAs...are the ball joints verified to be replaceable?
(Ball joints are a wear item and should be replaced when they exceed tolerance. I am gobsmacked that the Ram LCA does not allow the ball joint to be swapped out.)
It is not that they don't allow it, they don't sell it.Mevotech LCAs...are the ball joints verified to be replaceable?
You and me both!Mevotech LCAs...are the ball joints verified to be replaceable?
Really hope these work out great for you, because it's probably the root I have to take as well. Any chance you can post a pic of how they look on your truck?Well I had the Mevotech lowers installed today aaaaaand I am happy to report my front end clunk is finally gone. It was in fact the lower ball joints giving me fits. The front end feels like a new truck again.
Costs:
LT and RT lowers = $406
Install = $305
Alignment = $105
Total = $816
No clunking sound = Pricless
This is what I've been told as well... some play is built in.ZERO play isn't true, Ram actually has specs for the lower ball joints. They also have a different procedure than what you claim.
