Adding Passive Entry: How-to
Can i have the dealership permanently program it to my truck versus using Alfaobd? I rather not keep having to reprogram after dealer visits.
The only way is to convince the dealer to add the sales code to your VIN. And I highly doubt they will do that.
Bummer. Thanks.
The only time a dealer visit could possibly revert your settings is if they restore your vehicle configuration. The only time this is ever done is if there is a recall or TSB that has to do with the BCM, which is extremely rare.
Even in the rare instance this would ever happen, you don’t even need to manually go in and change the settings again. You just create a backup file of your BCM, and just go to restore configuration from backup if the settings get reverted.
@wradar What did you end up doing for the handles?
Yup, and they turned out great! I purchased the Diamond Black Crystal handles and lock covers, sanded them down (just enough to scuff them up all over), and then spray painted them with Rust-Oleum textured black spray paint, which is a "close enough that you can't tell the difference" match to the other handles. Two coats did the trick.
Tips:
  • Remove both of the rubber gaskets from the handle before painting it.
  • Use masking tape to tape off the parts of the handle you don't want to paint (e.g. the unlock button, the "grip" area on the back side of the handle, etc.) Use a razor blade or other precision cutting implement to cut the masking tape around the areas you don't want to paint.
  • When you're trying to get the giant two-plug harness from the door to the body re-installed in the body:
    • install the rubber cover back onto the harness before putting the harness back into the door. Ensure it's fully seated on the harness.
    • don't hold the door all of the way open. Instead, close the door a couple of inches, then fit the harness into the body. Closing the door just a smidge from full-open will create more room to maneuver the harness into the body hole.
  • It took me about two hours for the first door (I was also replacing the interior door handle release cable, which was an unrelated repair that may have added 30 minutes to the passive entry install). The second door took a bit over an hour, if I remember correctly. The tail gate also took about an hour. It's very likely someone less anal about checking their work every two minutes would get this done a lot faster than I did.
That doesn’t sound too bad then. I’ve been piecing parts together and been debating as of late.
Does anyone know the part numbers for trucks with delmonico red paint. I didn't see it listed in the column with all the part numbers. Does anybody know how to get in touch with Jimmy so that he can make me a harness for it. Thanks nicholas
I have a 2019 delmonico red big horn and used these:
6CV361RVAD x2 (handles)
6CV50NRVAC x1 (passenger cap)
6CV52NRVAB x1 (driver cap)
Quick question……So how much does it cost in parts and software to switch over to passive entry?
I’m sure the answer is in here somewhere but don’t have the time to search.
About $450 if you are buying everything.
Just used all this great info to add passive entry to my 1500. Thank you everyone that put all this information together, and thank you Jimmy for the harnesses! It was a pain in the butt, though the outcome is worth it!
If you are going to use the numbers below to order parts, double check them as things can change over time, so it's going to be up to you to verify you're getting the correct part when ordering. If you find a mistake please let me know so I can correct it.
5th Gen 1500 Handle and Cap Part Numbers
These should work on any of the 2019 and newer 5th gen 1500 trucks. Harnesses are going to be more specific based on your options, or you can just add the 2 wires and plugs to your existing stuff and save a good bit of money.
COLORBODY COLOR HANDLE, L & RBODY COLOR/CHROME HANDLE L & RHANDLE CAP, LEFTHANDLE CAP, RIGHT
Bright White6CV64GW7AD6CV361W7AD6CV50GW7AC6CV52GW7AB
Ivory White6CV64KGZAD6CV361WDAD6CV50JWDAC6CV52JWDAB
Diamond Black Crystal6CV64KXJAD6CV361XJAD6CV50KXJAC6CV52KXJAB
Maximum Steel Metallic6CV64KARAD6CV361ARAD6CV50KARAC6CV52KARAB
Granite Crystal Metallic6CV64LAUAD6CV361AUAD6CV50LAUAC6CV52LAUAB
Billet Silver Metallic6CV64JSCAD6CV361SCAD6CV50JSCAC6CV52JSCAB
Patriot Blue Pearl6CV64RPXAD6CV361PXAD6CV50RPXAC6CV52RPXAB
Blue Streak Pearl6CV64KCLAD6CV361CLAD6CV50KCLAC6CV52KCLAB
Flame Red6CV64PR4AD6CV361R4AD6CV50PR4AC6CV52PR4AB
Olive Green6CV64KFPAD6CV361FPAD6CV50KFPAC6CV52KFPAB
Replacement Clips for the 1500 door panels
Door Interior Trim Panel Retainer (Yellow): 6510747AA
Door Interior Trim Panel Retainer (White): 6510359AA
HD Part Numbers
Thank you to @01Time for providing the more comprehensive list below for the HD trucks than I had originally posted.
COLORBODY COLOR, FRONT LEFTBODY COLOR, FRONT RIGHTBODY COLOR, REAR LEFTBODY COLOR, REAR RIGHTBODY COLOR/CHROME, FRONT LEFTBODY COLOR/CHROME, FRONT RIGHTBODY COLOR/CHROME, REAR LEFTBODY COLOR/CHROME, REAR RIGHT
BILLET SILVER METALLIC1UJ81JSCAI1UJ86JSCAI1GH19JSCAF1GH18JSCAF6NV571SCAD6NV561SCAC6NV591SCAC6NV581SCAC
BLACK FOREST GREEN PEARL1UJ81KGZAI1UJ86KGZAI1GH19KGZAF1GH18KGZAF6NV571GZAD6NV561GZAC6NV591GZAC6NV581GZAC
BLUE STREAK PEARL1UJ81KCLAI1UJ86KCLAI1GH19KCLAF1GH18KCLAF6NV571CLAD6NV561CLAC6NV591CLAC6NV581CLAC
BRIGHT SILVER METALLIC1UJ81WS2AI1UJ86WS2AI1GH19WS2AF1GH18WS2AF6NV571S2AD6NV561S2AC6NV591S2AC6NV581S2AC
BRIGHT WHITE1UJ81GW7AI1UJ86GW7AI1GH19GW7AF1GH18GW7AF6NV571W7AD6NV561W7AC6NV591W7AC6NV581W7AC
BRILLIANT BLACK PEARL1UJ81AXRAI1UJ86AXRAI1GH19AXRAF1GH18AXRAF6NV571XRAD6NV561XRAC6NV591XRAC6NV581XRAC
DELMONICO RED1UJ81NRVAI1UJ86NRVAI1GH19NRVAF1GH18NRVAF6NV571RVAD6NV561RVAC6NV591RVAC6NV581RVAC
DIAMOND BLACK CRYSTAL PEARL1UJ81KXJAI1UJ86KXJAI1GH19KXJAF1GH18KXJAF6NV571XJAD6NV561XJAC6NV591XJAC6NV581XJAC
FLAME RED1UJ81PR4AI1UJ86PR4AI1GH19PR4AF1GH18PR4AF6NV571R4AD6NV561R4AC6NV591R4AC6NV581R4AC
GRANITE CRYSTAL METALLIC1UJ81LAUAI1UJ86LAUAI1GH19LAUAF1GH18LAUAF6NV571AUAD6NV561AUAC6NV591AUAC6NV581AUAC
MAXIMUM STEEL METALLIC1UJ81KARAI1UJ86KARAI1GH19KARAF1GH18KARAF6NV571ARAD6NV561ARAC6NV591ARAC6NV581ARAC
PATRIOT BLUE PEARL1UJ81RPXAI1UJ86RPXAI1GH19RPXAF1GH18RPXAF6NV571PXAD6NV561PXAC6NV591PXAC6NV581PXAC
PEARL WHITE1UJ81PWQAI1UJ86PWQAI1GH19PWQAF1GH18PWQAF6NV571WQAD6NV561WQAC6NV591WQAC6NV581WQAC
TRUE BLUE PEARL1UJ81KBUAI1UJ86KBUAI1GH19KBUAF1GH18KBUAF6NV571BUAD6NV561BUAC6NV591BUAC6NV581BUAC
WALNUT BROWN METALLIC1UJ81RUWAI1UJ86RUWAI1GH19RUWAF1GH18RUWAF6NV571UWAD6NV561UWAC6NV591UWAC6NV581UWAC
HYDRO BLUE METALLIC1GH19MBJAF1GH18MBJAF6NV571BJAD6NV561BJAC
OLIVE GREEN METALLIC1GH19KFPAF1GH18KFPAF6NV571FPAD6NV561FPAC
The following is a breakdown of the parts you will need to assemble your own 2-wire harnesses for the doors, as well as the rear antenna. All of the connectors and terminals can be found at Mouser or Digikey, except for the Yazaki stuff.
Rear Antenna Wiring Parts
22AWG wire (2 colors to make it easy)
Heat shrink tubing (recommended)
Braided wire sleeve (recommended)
Rear PE Antenna: 52112204AA or 56046957AA should work in this location
2019 & 2020 Rear Fascia Connector Terminals: TE Connectivity 1241380-1
2019 & 2020 Rear Fascia Connector Wire Seals: TE Connectivity 828904-1
2021 Rear Fascia Connector Terminals:
2021 Rear Fascia Connector Wire Seals:
2019+ Rear Antenna Connector Shell: TE Connectivity 1-1438608-5
2019+ Rear Antenna Connector Shell Terminals: TE Connectivity 1355717-1
2019+ Wire Seals for Antenna Terminals: TE Connectivity 963530-1
Door Handle Wiring Parts
18AWG wire (2 colors to make it easy)
Door Connector Terminals: Aptiv 10762775
Door Handle Connector Shell: Yazaki 7283-6079-30
Door Handle Connector Shell Terminals: Yazaki 7116-4720-02
Yazaki parts are hard to find without ordering minimum quantities. One option is to call SMD Inc, and see if they’ll send you free samples (2 connectors, 4 terminals).
For anyone that orders the OEM parts and can confirm they work, if you PM me the part numbers, year and color of your truck, and any additional options you have from the factory in the doors, I will make one of the posts I have reserved dedicated to a list of confirmed part numbers for each color there is. This will help a lot of people out having a short list specific to each color rather than having to search it all.
Do you know what the part number for the handles are for the built to serve edition? I have the gator one and my handles are black like a matte color
HD Part Numbers
do you know what the official color or part number is for built to serve editions in gator is?
Does anyone know the part number for the male pins used on the rear fascia connector used on the 2021+ models?
For 2021 the male pin for the rear fascia is mouser part# 571-1718760-2 For the seal the mouser part# 571-963530-1
I ended up ordering the 56046957AA from bamwholesaleparts.com and got it in about a week. I havent installed so cant confirm it works but others have and said it works with minor adjustments to the mounting position but functions fine otherwise.
56046957AA looks to be backordered. Earlier in the thread it showed 52112204AA worked as well for about $5 and in stock. Any confirmation that works for sure? The other part number seems to be the most common.
Installed on my 22 Ram 1500 this weekend. Great instructions from MayhemMoore, very easy to follow, Passive Entry option is now in my settings menu. Used Jimmy07's cables, professionally made (labeled, etc.) - I would highly recommend getting these cables from him. Passive entry is working all around.
I used 52112204AA for a 2019 big horn and can confirm it works fine.
I'm 95% of the way done adding PE to my 2022 2500. I have broken two pin connectors on Jimmy's door harnesses(one on each side) being a little carless and made a mistake. He has been kind enough to send me a few replacements, but I'm inexperienced in crimping these types of pins.
I've ruined one replacement trying to crimp it with some needle nose pliers. I don't want to ruin any more, so can someone explain or point me to a resource that shows the proper way? I'm not opposed to buying a crimping tool if needed as I plan to add PE to the rear door in the future. Thanks.
I have been trying to locate the part number for the cheaper antenna for 21 ram 1500 thanks in advance
Get this one and you're set.
  • Back
