56 Pontiac
Thanks guys! On my 'to do' list ...Not sure where they were purchased as I am 2nd owner. There is one on drivers side. Looks a little tight but doable.
Dave
YesCan u install this with the etorque engine? I only really want the cooler look and slightly deeper sound. I don't need it to sound like a drag race car.
Yes, the Ram G/T comes equipped with this, and I think you can only get the G/T in etorque (someone correct me if I'm wrong on thisCan u install this with the etorque engine? I only really want the cooler look and slightly deeper sound. I don't need it to sound like a drag race car.
)This is kind of correct.I purchased a Ram Air flow from the dealership but found out that even with them installing, the warranty is only 1 year. If the CAI is found to be the root problem of an issue, your factory warranty will not cover the repair. I’m not even opening the box, I am selling it as the dealer wants to charge me half as a restocking fee.
I agree but it was the service manager that let me know they would not cover. They stated if it is determined to be the root cause ex sensor error, debris in engine, then even though vehicle under warranty, the warranty would be denied. Just didn’t feel the gains if any were worth the risk.This is kind of correct.
If the CAI is the problem they would not cover the repair.
If the problem is not the CAI they would cover it.
An air intake can't cause a problem, it's air.
This is the exact same things using an after market part.
The aftermarket part is not covered and any damaged caused by it would also not be.
I wouldn't worry about it man, what are they going to say you are putting bad air in?
Also keep in mind dealerships have a bunch of wiggle room when it comes to warranty repair work.
If you got the part from them and showed the receipt for it they are FAR more likely to do work as they know you spend money with them vs if I came in with it installed but not by them they are likely to turn me away and tell me to go pound sand.
Find a new dealer and service manager. He isn't all there and doesn't know his product or warranty.I agree but it was the service manager that let me know they would not cover. They stated if it is determined to be the root cause ex sensor error, debris in engine, then even though vehicle under warranty, the warranty would be denied. Just didn’t feel the gains if any were worth the risk.
Yeah, don't go back to that dealership and give them your money.I agree but it was the service manager that let me know they would not cover. They stated if it is determined to be the root cause ex sensor error, debris in engine, then even though vehicle under warranty, the warranty would be denied. Just didn’t feel the gains if any were worth the risk.
To be clear, you probably won't see any gains. If you bought this for performance reasons you'll be disappointed.I agree but it was the service manager that let me know they would not cover. They stated if it is determined to be the root cause ex sensor error, debris in engine, then even though vehicle under warranty, the warranty would be denied. Just didn’t feel the gains if any were worth the risk.
Where are you located? I’d buy it.I purchased a Ram Air flow from the dealership but found out that even with them installing, the warranty is only 1 year. If the CAI is found to be the root problem of an issue, your factory warranty will not cover the repair. I’m not even opening the box, I am selling it as the dealer wants to charge me half as a restocking fee.
I’m in Ky but Sold it this morning.Where are you located? I’d buy it.
I wonder what the service manager is going to do when he has to do warranty work on a RAM G/T that comes with the Mopar CIA from the factory...Find a new dealer and service manager. He isn't all there and doesn't know his product or warranty.
Great question, I actually asked. As it was factory install on that model it is covered under 3 year 36. Since Mopar lists it as a performance part, if installed aftermarket even when done by Mopar tech, it is only a 12 month warranty. Even states not covered in the Mopar MVP plans on page 4 since performance Part.I wonder what the service manager is going to do when he has to do warranty work on a RAM G/T that comes with the Mopar CIA from the factory...
What a dork...
Just send it to me. I'll dispose of it for you.So I just bought the Ram Airflow from @Accessory.Parts (Great experience BTW, Highly recommend..) but after reading the info directly above, now im leery about doing the install. What a bunch of BS. The whole point of me buying a MOPAR part was so it would be a true factory part. Even stranger they would deny a warranty because its standard issue on the GT models - https://www.ramtrucks.com/2022/ram-1500/gt-special-edition.html -
Now I do not know if I should even pull it from the box
Let your balls drop and just install it. Most dealers won't say a word about the RamAir intake in your truck and voiding warranty. Shoot, most dealers won't say anything about any aftermarket intake. I had my passenger side valve cover replaced under warranty on my truck and I have the Vararam intake. Dealer didn't say a wordSo I just bought the Ram Airflow from @Accessory.Parts (Great experience BTW, Highly recommend..) but after reading the info directly above, now im leery about doing the install. What a bunch of BS. The whole point of me buying a MOPAR part was so it would be a true factory part. Even stranger they would deny a warranty because its standard issue on the GT models - https://www.ramtrucks.com/2022/ram-1500/gt-special-edition.html -
LOL alllllright. I just dont want to f*ck up my chances of getting something handled on a vehicle that has its share of problems happen.Let your balls drop and just install it. Most dealers won't say a word about the RamAir intake in your truck and voiding warranty. Shoot, most dealers won't say anything about any aftermarket intake. I had my passenger side valve cover replaced under warranty on my truck and I have the Vararam intake. Dealer didn't say a word
