suln
I have a stock 2022 4x2 Hemi
I want to put front and rear sway bars on.
How do I go about purchasing the Roadmaster bar? Do i purchase a 2500 kit?
Also, im tryin to get a comparison of Front and rear kit from Hellwig and front and rear Roadmaster? Anyone with input is appreciated!
vincentw56
I'm not sure I understand. Do you have a 2500? If so, you might have better luck in the hdrams.com site.
Rock Crawler
Lone Star State
For the 1500’s, the Hellwig rear sway bar is a great addition. Hellwig states on their website that there is no reason to replace the stock front sway bar.
suln
I have a 1500. On my signature it shows what i drive. But, I have seen posts and replies when discussing the rear sway bar options. And some me tion OEM 2500 bars for the rear of the 1500 bc they are beefier. And others say Hellwig or Roadmaster.
suln
Ok, cool, ive also read that front sway bars are beneficial for RWD trucks and cars, thats why I was thinking of doing both. I may try out the Hellwig and go from there. Thanks
vincentw56
Sorry, we can't see signatures on the mobile app.
Your truck has front and rear sway bars from the factory. There isn't an aftermarket front sway bar option at this time. The rear Hellwig sway bar replacement is a very good upgrade.
Jeffjad
Southwest PA
Hellwig rear sway bar is a great addition. I'm not sure there are any aftermarket front stabilizer bar options out there yet.
suln
What is the benefit/feeling after installing? What are your impressions?
suln
I meant aftermarket sway bars, but what do you think about the Hellwig upgrade? Is it noticeable and worth it?
Very noticeable and very good difference. Truck is a lot more firm and corners so much better. I went right to stiffest setting(closest hole) because I wanted the max benefit. Most people use the center hole.
suln
Hmm ok nice. Is the ride quality affected? Like over bumps and dips? Is the “firmness” only wen turning and steering adjustments?
Mostly just when turning. Ride quality is better overall because it doesn't feel like it floats as much.
suln
Nice ok, i hust dont want a “stiff” riding experience, i just want better turn in and less roll so it sounds like i will like what it is going to do
suln
Sure, a little stiffer. If you like the plush ride then I suggest leaving the truck stock.
No thanks, im not ONLY after the plushest ride. I am just trying to get your opinion VERSES stock ride. I want to mod the truck and i understand that non oem parts change the the stock feel.
Jeffjad
Southwest PA
Gotcha, here's a link to 18 pages of opinions on the Hellwig.
