Upfitter Switches
I have the air ride so I think this is the one That might work with mine. 68376641AE does anyone know if the trailer height button toggles up and down?
The answer is no after further investigating... Looks like I have to wait, hope and pray that they will put these in the Rebels or other trims with the ORP. :( :( :(
While reviewing your order for processing I've discovered an issue. Part 68376640AE is currently on national backorder with the automotive manufacturer and has no estimated date of resupply. We are unable to acquire it at this time. Unfortunately, despite our best efforts, sometimes the demand for certain parts and accessories exceeds manufacturers’ current supplies. I apologize for the inconvenience.
If anyone knows of a place that has stock please let me know
Edit: part number is for the 6 switch panel
What? #mod @admin #wtf
Ok so i just got mine working today with the 4wheelelictronics kit and the mopar switch. I changed the 3 alfaobd setting that where mentioned above and it took 2 days for the setting to take and the settings to show up in the 12” uconnect system.
What year is your truck?
Where do you wire additional accessories to? Is there a relay panel in the engine bay similar to the HD?
Damn all you guys and your 2021’s +.
Can’t wait to try it!
Just curious what part number this unit is. I found on the site a decoder sheet but part numbers dont appear to match images of the switches I ve been seeing. Any help would be great.
Thanks
Thanks
I believe you need:
68376640AE
From this post here:
This is 68376640AE:
68476031AB has the diesel exhaust brake button instead of the traction control button, so you don’t want that on a 1500.
68376640AE will work for 2019-2022.
2022 Rams DO use a different part number for that same switch bank, but only because the top row of buttons circled in the pic have a matte finish instead of gloss.
Does anyone know the part number for the ones with the matte finish?
68376640AE - top row is glossy
Does anyone know the part number for the ones with the matte finish for a 2022?
Not sure which one it is because they don't tell you :censored: https://store.mopar.com/v-2019-ram-2500--laramie--6-4l-v8-gas/electrical--switches scroll down about 2/3 of the way and good luck. Maybe make a list and take them to a dealer and see if they can figure it out. Or go to a dealer and see if you can see one in a truck and have them look up via the VIN.
