My Maxtrac lowering installation
ferraiolo1
North Central PA
I haven’t. Just around the block. Here are the measurements. Remember I already had 2in drop springs in the rear for the initial measurements.
Mopar_maxi
Looks great, congrats!
I may go the adjustable panhard bar route as with the relocation bracket you can't use a Hellwig swaybar.
Have you had it up to speed (80+)? Any weirdness in the way it feels at that speed? How level does that panhard bar sit when it has all 4 wheels on the ground?
He has the same exact rear setup as I do. I’ve been 100+ with zero sway or any issues.
Mopar_maxi
I'm gonna have to give that a shot so I can get my Hellwig bar back on.
The panhard bar isn’t at the ideal angle but I have had zero issues. Also the IHC 3/5 kit doesn’t even come with a relocation bracket. These trucks don’t seem to be affected as much as the 4th gens are with the panhard bar angles. Also in this picture I was laying on the ground so the angle looks more steep than it truly is F47B6AA8-4177-4AD0-9003-AB1D82DD482C.jpeg
ferraiolo1
North Central PA
Better? No, same, kinda.
The 5100s give a more controlled ride. Less squishy than the Oem shocks.
Clv22p
Nashville, TN
Report back when you get a few road miles on it. I’d like to know how it rides and handles.
I’m currently on a rear level, but wanting to do a 2/4.
I lowered a 3rd gen ram and not wanting to have the same issues I had with that truck. This truck is too nice
Mopar_maxi
I have about 700 miles on my 2/4 kit. I love it. Driving around you can hardly tell it’s lowered. It drives great and handles perfect. I think the bilsteins really made all of the difference.
31RamIt
Can anyone comment on towing with this setup?
Sent from my SM-G991U using Tapatalk
U
User_67930
Guest
I have a little over 3k miles on mine with zero complaints, I'd do it again in a heartbeat.
In fact I'm getting ready to go lower.
ferraiolo1
North Central PA
Haha. With the stock tires it makes me wanna go lower. But once I stick my 305s on it. The fender wells will be filled in nicely
31RamIt
I'm pretty excited to see how it turns out, as well.
Idahoktm
North Idaho
Start to finish I was at 4hrs. Including drinking my coffee, unboxing everything, and trying to stay warm, (it was 20*f this morning)
Time to pack some insulation between those studs and heat your garage. It's 20° here today and my garage is a toasty 60°. I've spent many winters busting my cold knuckles in a freezing garage. Miserable.
