TAZER DT for 2019 RAM 1500
FuBaR2508
Nevermind. I used my Pulsar to change the tire settings, but the Tazer is reading them as being set to 34.41
I can try changing to lower settings. Do I need to fill reboot and 2 sleep cycles each time I change it?
Yes, you should always do a full reboot. Sleep cycles are not ways needed, but should be done
coolblue24
Has anyone used their Tazer on a new 2022 with U-Connect 5? I updated the software on mine and moved it to my new truck. I find it very glitchy and hard to navigate. It requires several button presses to advance to the next screen and it's hard to read as the radio info seems to be fighting with the tazer info on the screen and they appear as a mix of the two. I did find that turning off the radio helped. Also been having a problem with the back up cam on with turn signal getting frozen on the screen, rendering it useless until you can shift the truck into park, which clears the freeze. Tough to do though when flying down the highway.
ekaz
I have the same experience and going to reach out to them and see if there are any updates in the works. I have the front cam turn on with the parking sensors and same deal that it stays on until I can change gears. I'm going to see if they can add a timeout or something.
Croak
Central FL
Ditto, just got my '22 Limited on Wednesday, and installed my Tazer DT as soon as I got home (long time Tazer user with my Challengers). Had to turn off both cam modes, and it's a struggle to cycle through settings, since it seems UConnect 5 is sending data updates to the Audio screen a lot more often than version 4.0 did.
Also made the mistake of setting Brake Hold to ON, which would cause an ABS error with Auto stop/start enabled and leaving from a stop.
bevo
I had to sell my 2019 1500 etorque. Loved the functions the Tazer enabled while I had it. So, got a Tazer DT to sell that's only a couple months old. Please dm me with your best offer. Available for pickup in Austin, TX. Can also mail it if willing to pay for postage.
Thanks!
ekaz
There is a new firmware version, 18.1.2 that should address the menu navigation issue as well as added a couple of other items.
Croak
Central FL
I started with 18.1.2, updated before I installed it last week, and yet the menu navigation problem is present.
UnclJim
Long Island
has there been a correction of this turn back issue? i tried to use my tazer today on my '22 rebel and it gets to confusing
HemiDude
Ohio
When I asked the Tazer folks if mine would work on my new '22, they replied yes, and suggested updating to 18.1.3. I haven't installed mine yet though, want to make sure everything else in the truck is error free for a couple of months first.
UnclJim
Long Island
pretty sure I am up to date but I'll double check
xxmsfxx
Anyone want to get another group buy going? Im in for another order!
bnh105
Anyone having issues with the park sensors becoming unavailable? Can’t turn them on or off, just says unavailable.
I am, did you get yours figured out?
bnh105
So I changed the tire size from 35" to 34". Did a full reboot and 2 sleep cycles and the sensors still show unavailable. Does it take some drive time for the sensors to re-adjust themselves?
Did you ever get this figure out? I’m having same issue too
bnh105
I have 285/55/22 but anything over 33.34 makes my park sensors not work, has anyone solved this issue yet that has this? I’ve talked to zauto with nothing but generic responses so far and that it should be working.
EricBrums89
I set mine to 34.5” and didn’t have any trouble with my sensors working. I have the menu navigation issue though. It’s awful. Makes me want to unplug it and get rid of it. I hope they fix it soon. I also can’t set my DRL to the halos. It’s either low beams or turns. I’m at 18.1.5 version.
CptnMorgan
Thanks!
Still available?
