brian42
The only real use for it besides having a convenient number to read is to control the climate control (AUTO) if you have it. I'm not sure if any other functions (e.g. ECM) use it for calculations.I don't know about the engine light, but somehow I missed this conversation when it first came up last year.
I remember in the old days we just stuck our head outside to see what the temperature was. Back then there were only 3 temperatures:
1. Cold as balls - put on a sweater or a jacket and a wool cap. Turn on the heat.
2. Just right - only short sleeves needed. Save on utility bills.
3. Hotter than hell - go inside and crank up the AC.
Unless I had money riding on the over/under of today's forecast, I can't conceive of any situation where I would actually even care if the temperature gauge was accurate or not.
AUTO uses dash vents only and I prefer dash/floor so I always control it manually. In the old days if I was cold I would slide/turn the knob more red, if I was too warm I would move it more blue, and if I was just right I'd leave it. The only difference now is that I have numbers that I make higher (more red) or lower (more blue).
