Dookie
Initial impression is WOW!!! Really hit it out the park, IMO perfection.
A couple of things while it's fresh, if you have a Hellwig swaybar with adjustable end links, unbolt the drivers' side end link to allow clearance for removal/install, probably a good idea on stock sway end links too. Second, if you bought a G/T and have to second guess if it has the correct exhaust, IT DOESN'T. Third, if you buy the G/T exhaust, and have stock resonators get the passenger side RH resonator as well, a very noticeable difference between the drivers' side and passenger side.
Sorry, no vid yet, will try and get a cold start-up for y'all when it cools down.
