Thanks to everyone on this thread for all the parts required, procedures, tips and pictures.  This was a much easier job than I expected due to all of the posts.  I don't think much can be said that hasn't already been said but I did want to clarify the parts required as there were some discrepancies as I was creating my parts list.  Most recently there has been a few posts for the exact parts list needed for the 23 gallon swap but not for the 26 gallon swap.  So I am listing below the exact parts I used for my 26 gallon swap.
| Part Number | Description | Comments |
| 68408875AF | 33 gallon fuel tank |  |
| 52030458AB | strap (front strap for 33) - fuel tank |  |
| 06104717AA | nut flange hex | Need this for the front mounting strap |
68307831AB
57008595AA | tube - vapor (for 33 gallon tank) | 68307831AB is for a 2019-20 3.6L V6 and 2019 5.7L (34 1/2" long).  Although this fit, it was too long for my 2020 5.7L and seemed too tight.
57008595AA is for a 2020-21 5.7L (31 1/2" long). This fit perfectly for my 2020 5.7L Crew Cab. |
| 52029908AB | hose - purge |  |
| 52030443AB | bundle - fuel line |  |
| 52029888AC | canister - vapor | Possibly optional as I believe some people have reused their canister from the 26 gallon tank |
| 52029909AC | hose - filter to Canister | Probably not needed, can reuse existing hose (although the 33 gallon tank hose is slightly different) |
| 52029964AD | skid plate 33 gallon (73" long) | Optional - If you don't have the skid plate currently you also need a hanger (68303523AB) and bolts/nuts to mount it |
| 68418923AC | Reinforce fuel strap - (for DS body) | Optional - only if you do not have the 3rd hanger and want to use this for the 3rd strap |
Two parts I did not need were 68312139AB (hose - vent) and 68312140AC (hose - fuel return).  These were listed very early in this thread for the 26 gallon swap but are not necessary.  Nobody ever clearly stated that they were actually not required although those that have swapped out the 23 for the 33 never listed these as required.
