chino
- Oct 21, 2018
Hi all,
I installed a RC 20 inch light bar inside the bottom grille, install went great and simple, now the wiring harness is somewhat of an issue, the instructions tell you to hook it up to the + and - side of the battery, but i do not want constant power being drawn, the switch turns it off and on but I do not want that switch to be powered unless the truck or accessories are on. Other than that the light looks great. Any ideas on a ignition wire inside the hood? The harness is inside the hood and I don’t want to have the harness and relays inside the cab. Thanks
