Adding Passive Entry: How-to
Finally got my handles working, thanks Jimmy07 for the harnesses and everyone for the info! I used AlfaOBD on a windows laptop and the program definitely isn't user intuitive so it took me awhile to figure out what to do but I got all the settings updated. Even got the fog lights to stay on with the high beams.
Just wanted to update the HD door handle list. I was able to pull these from an electronic parts catalogue (@MayhemMOORE: feel free to delete this post and update the original):
COLORBODY COLOR, FRONT LEFTBODY COLOR, FRONT RIGHTBODY COLOR, REAR LEFTBODY COLOR, REAR RIGHTBODY COLOR/CHROME, FRONT LEFTBODY COLOR/CHROME, FRONT RIGHTBODY COLOR/CHROME, REAR LEFTBODY COLOR/CHROME, REAR RIGHT
BILLET SILVER METALLIC1UJ81JSCAI1UJ86JSCAI1GH19JSCAF1GH18JSCAF6NV571SCAD6NV561SCAC6NV591SCAC6NV581SCAC
BLACK FOREST GREEN PEARL1UJ81KGZAI1UJ86KGZAI1GH19KGZAF1GH18KGZAF6NV571GZAD6NV561GZAC6NV591GZAC6NV581GZAC
BLUE STREAK PEARL1UJ81KCLAI1UJ86KCLAI1GH19KCLAF1GH18KCLAF6NV571CLAD6NV561CLAC6NV591CLAC6NV581CLAC
BRIGHT SILVER METALLIC1UJ81WS2AI1UJ86WS2AI1GH19WS2AF1GH18WS2AF6NV571S2AD6NV561S2AC6NV591S2AC6NV581S2AC
BRIGHT WHITE1UJ81GW7AI1UJ86GW7AI1GH19GW7AF1GH18GW7AF6NV571W7AD6NV561W7AC6NV591W7AC6NV581W7AC
BRILLIANT BLACK PEARL1UJ81AXRAI1UJ86AXRAI1GH19AXRAF1GH18AXRAF6NV571XRAD6NV561XRAC6NV591XRAC6NV581XRAC
DELMONICO RED1UJ81NRVAI1UJ86NRVAI1GH19NRVAF1GH18NRVAF6NV571RVAD6NV561RVAC6NV591RVAC6NV581RVAC
DIAMOND BLACK CRYSTAL PEARL1UJ81KXJAI1UJ86KXJAI1GH19KXJAF1GH18KXJAF6NV571XJAD6NV561XJAC6NV591XJAC6NV581XJAC
FLAME RED1UJ81PR4AI1UJ86PR4AI1GH19PR4AF1GH18PR4AF6NV571R4AD6NV561R4AC6NV591R4AC6NV581R4AC
GRANITE CRYSTAL METALLIC1UJ81LAUAI1UJ86LAUAI1GH19LAUAF1GH18LAUAF6NV571AUAD6NV561AUAC6NV591AUAC6NV581AUAC
MAXIMUM STEEL METALLIC1UJ81KARAI1UJ86KARAI1GH19KARAF1GH18KARAF6NV571ARAD6NV561ARAC6NV591ARAC6NV581ARAC
PATRIOT BLUE PEARL1UJ81RPXAI1UJ86RPXAI1GH19RPXAF1GH18RPXAF6NV571PXAD6NV561PXAC6NV591PXAC6NV581PXAC
PEARL WHITE1UJ81PWQAI1UJ86PWQAI1GH19PWQAF1GH18PWQAF6NV571WQAD6NV561WQAC6NV591WQAC6NV581WQAC
TRUE BLUE PEARL1UJ81KBUAI1UJ86KBUAI1GH19KBUAF1GH18KBUAF6NV571BUAD6NV561BUAC6NV591BUAC6NV581BUAC
WALNUT BROWN METALLIC1UJ81RUWAI1UJ86RUWAI1GH19RUWAF1GH18RUWAF6NV571UWAD6NV561UWAC6NV591UWAC6NV581UWAC
HYDRO BLUE METALLIC1GH19MBJAF1GH18MBJAF6NV571BJAD6NV561BJAC
OLIVE GREEN METALLIC1GH19KFPAF1GH18KFPAF6NV571FPAD6NV561FPAC
Thanks for providing this. I updated the original parts listing in post #7 with it.
is it cheaper to piece together like this now or just buy the kit? i think i saw it somewhere for like $500 for everything with the wiring harness
The full kit that includes the rear antenna provision is $600. You can source the brand new parts and use my harnesses for about $250 cheaper to get the fully factory functioning feature.
Easier too, it'd be more work to replace the entire door harnesses instead of just add the two required wires.
What happens if you just hook up the rear bumper antenna without getting the door handles? I just want it to open when I walk up to the truck, without using the handle, is this possible?
I’d like to know if this is possible too. I have passive entry from the factory but this would help with unlocking the back doors if it would just unlock when I approach.
It won't auto unlock just by walking up to the truck. The rear antenna is for opening the tailgate without unlocking the truck first.
I was just wondering if there was a way to change the programming to unlock when near the truck using that antenna, but I guess that's not yet possible. It should be though. Would eliminate needing to replace the door handles
It’s not possible at all on these trucks. The antenna only senses the fob, but a physical switch must still be used to passively unlock the doors.
I added it this weekend, but I broke the little white plastic thing on the door to body connector so the boot doesn't sit flush. Anyone know what that part is called? Or a part number?
2020 Bighorn Night Edition, 5.7 Hemi w/eTorque
I did the same thing. Were you able to remedy the situation? did you have to buy a whole new harness?
Had an issue pop up intermittently (happened twice before) where the drivers side door latch wont catch, so the door just bounces open when shutting it. The latch rotates and locks with the button on the handle or inside when Im in the truck, just not when I try to close the door. I have to climb over the rear seat to open the door by the interior handle. Normally, it just goes away and closes as normal.
I went to the dealership to have them fix the latch (because I just moved and dont have all my tools) and they pulled a DTC of B1A75-01 and 13. The tech said the door wont latch because the rear antenna is missing (I broke the leads during install). I think he was talking about the FOBIK security feature but didnt really know what hes talking about. Like I said, was never an issue for the 6 months its been like that, except for those two instances where it worked itself out after an hour. If he is right, it seems to me that turning the rear antenna off in AlfaOBD would get rid of the error and allow my door to close again.
I tend to think that its more of a mechanical issue where the door handle latch slid off the catch inside the door. I know @Jimmy07 is the resident expert here for this project. If anyone has had similar issues or can clue me in about the ECU potentially causing this. Please let me know. I love having passive but the dealership tells me that I need to go back to stock and flash the ECU to be bale to close my door again.
Thanks in advance
Thanks in advance
The latch issue is 100% mechanical, and has zero to do with the passive entry system or rear antenna.
Does anyone know what the part number would be for actual front drivers door wiring harness with passive entry? 2021 BIG HORN. I have searched on many mopar part sites but I just can't get an exact number.
Another successful install. I did not do the hidden bolts method. I did the service manual way which was super easy, no issues at all doing it that way. The " how to " write up was incredible and the help from forum members was amazing. Jimmy's cables and service was awesome.....top notch!! Thanks to all
