Tazer DT Amber DRL Settings Help
Sdnyc82
Hello,
Can someone post their Tazer DT Amber DRL settings?
I have DRL turned off on my uconnect settings, but all I get is the white LED straps above and below the headlights.
What settings should I have enabled on my tazer DT to make the top row Amber?
Current settings on tazer DT:
DRLType: USA
DRL loc: Turn
DRL Drop: NO
TIA!
Le_Slacker
London, Ontario
The LEDs you have on are called the halos
There’s is a tazer setting to disable Halos if that’s what you want to do
piening2150
The DRL has nothing to do with the upper/lower accent lights. The Tazer is just reassigning the DRL light (stock is the headlight running lower power) so if you've already reassigned DRL to the turn signal, then recheck the DRL box in Uconnect to activate them and see if they're on.
Howie Dub
Have you turned on the Amber DRL setting in the Live settings menu when your engine is on?
djdnl
Alberta, Canada
Hello,
DRLType: USA
DRL loc: Turn
DRL Drop: NO
TIA!
Did you find the solution?
MurphBigHorn
Anyone know if the tazer. I don’t own it yet!
I
don’t have the led package. I really like the orange lights on the head lights. It has a mean glow to it. Can I run those as my day time running light if I got a tazer?
RHCan
USAF Retired Vet
North Texas
Hello,
DRLType: USA
DRL loc: Turn
DRL Drop: NO
TIA!
Your settings are correct
Amber will only show when truck is in gear and drl is turned on in uconnect
Soon as you put truck in park they will revert to white.
Thats how it works on mine
CogitoErgoLevo
Los Angeles
You need to have DRL set to ON in your Uconnect settings for it to work.
If DRL is set to OFF in Uconnect then only the halos will be on
Pejcinoski
Can someone help here..
I have Limited 22 Australian Conversion
The truck had no DRL activated only when lights are on the the white straps top and bottom of light are on and when lights are off there is no LED drl
I have changed the settings to
DRLType: USA
DRL loc: Turn
DRL Drop: yes
And now I only get the top strip of led light up not the bottom? What can I change to get both LED strips to light up? And also how can I get them to turn the white led not amber?
leojiangcy
DRLType: USA
DRL loc: Turn
DRL Drop: yes
hi,I have a NZ one , I did the same sitting with you but I got nothing turned on. do you get right sitting to turn the DRL? Thanks
Dewey
WI
These are the settings I use for only Amber DRL’s.
This needs to be changed in LIVE settings too.
Dewey
WI
There is no upper amber. I believe only TRX has those.
Only the lower amber will be on.
Also if I don’t disable the halo’s the amber lights will not turn on even if activated.
Darksteel165
Massachusetts
What headlights do you have.
I only have Amber lights up top, bottom is white (I disabled them via signature lighting)
Dewey
WI
Premium Lighting Group. Amber lights are only bottom (turn signals). Signature (halo’s) are top/bottom. I have those turned off during the day. Only amber on for DRL’s.
Dewey
WI
My LED headlights. (Premium Lighting Group)
This part turns yellow (turn signal)
Halo’s only at remote start. (when activated without amber) Unfortunately they dim after turning to run mode. I would prefer these for DRL’s but not option to keep them bright.
Obviously there must be different configurations depending what model or lighting group you have. Being the Premium Lighting Group surprised they’re not the same as a Limited.🤔
