Waterfowler41
Chicago
These look nice! What brand shocks? They look like Icon package.
These are nice and I almost feel bad installing them on my truck.
This is Fabtechs mild lift kit with uniball ucas. Part # K3171DL. Shocks and coilovers are Dirtlogic (Fabtechs shock side).
HEMIJAKE
Potter County, Pa
Finally ordered a tri fold tonneau. Normally, one of the first things I do with a truck. I put it off for a while with this one because I didn't really need one yet, as it has been summer and the weather has been good. Came home from hockey practice with the boy the other night. Completely forgot our gear in the back of the truck, then it rained all night long. Lesson learned.
Whoa_Ram
Azle TX
I thought DirtLogic, but didn't see anything when I did a quick search. Give us an update on how they ride after you install. I need to change my setup as my UCA's are hitting the springs when they droop down. :( Just noticed this on my past weekend trip jumping over some curbs haha.
djevox
VP of Creative Thinking
MD
Why don’t they make the ram in that color? I (surprisingly) like that a lot.
Waterfowler41
Chicago
Yup I’ve had that issue in the last, tried replacing the UCAs but ultimately swapping out the factory struts for Bilsteins resolved it.
Whoa_Ram
Azle TX
Yeah I don't think changing out the UCA's will change it as the swinging motion they have is still the same, so I'm looking at coilovers right now. Wish I had a few grand laying around so I could just over a kit before my next vacation coming up, but oh well.
Dogpatch
Coldstream, BC
Just got the wheels on. Pictures don’t do justice on the awsome convex look of these wheels. My truck definitely needs a lift (it has a reverse level right now). Hopefully Real Truck’s resolution department gets the right lift kit for me from Eibach quickly.
Wheels: 22x10 -19 offset Fuel Contras in black/machine finish.
Tires: Toyo Open Country AT3 LT 285/50/22. 33” tall and 11.5 wide.
My wallet: 😥
Looks good but I’d be investing in some mud guards if you want to keep your paint on the truck.
brian42
San Diego, CA
Hi FLiPMaRC, I ordered a 2022 RAM 1500 Laramie with the Bed Utility Group that is being delivered soon. I am also looking at the TonnoPro Hard Tri-Fold. Did the bed rails in the Bed Utility Group cause any issue installing the TonnoPro Hard Tri-Fold? I would appreciate hearing of your experience. Thanks!
I have the BUG and a soft tri-fold tonneau that has the exact same latches and I have no interference issues.
The front clamp is a screw type to apply tension so is shallow and does not interfere with using the utility rail/cleats at all. The rear clamp is a cam and the handle is longer so will contact the utility rail when the clamp is fully set. Not a big deal as the only limitation is that you cannot put your tie-down cleat on the rear-most notch when you have the cover on.
I'm looking to eventually upgrade to a hard tri-fold and the TonnoPro is on my list of finalists.
Aschulte13
All the ladies going to want to ride in the back seat
You planning on carpet?
If not, consider this... For my bed divider I used orange peel wall texture and bedliner spray. Turned out great.
I tried a few different bedliner/undercoating sprays. The duplicolor bed armor was my favorite. Dries quick, covers wood great, and had the most texture to it.
Good idea with the orange peel for texture. That is sprayed with bed liner. I did a black coat of spray paint then topped it with bed liner. The orange coat would be good to hide my imperfections and screw holes.
Aschulte13
How does it sound? Do the storage boxes in the floor still open?
Post up a build sheet for the box with dimensions and such!!
Yeah storage boxes open. Lots of room for dogs and manly stuff back there now. Here is my “drawing” looks like a crazy person made it right now. But I’ll redraw with better dimensions if I get time. Basically traced out 1:1 on cardboard to check fit.
Ldc2335
Cheap tube of paintable caulk and a putty knife would work well for that too. I was shocked how much the wood absorbed the undercoating/bedliner spray.
I'm thinking of doing one like yours but half it, then carry the same outside frame dimensions to the other side, to make a cargo tray. I've grown fond of the flip down oem one I have and don't want to lose that feature. Wonder if my sundown from my last vehicle would have enough depth. Do you remember the depth dimensions?
Whoa_Ram
Azle TX
Appreciate the information. Now I have to look at getting a good set of springs or coilovers. I have my heart set on Fox, but the more I think about it, I don't want to spend the money on that anymore. I rather plan my trips with my little girl and enjoy the moments.
djevox
MD
F’in Real Truck. What a nightmare to deal with. They insisted that the part number that they had for my Pro truck stage one lift kit was the one I needed, while Eibach tech reps said that was wrong. After going back-and-forth with Real Truck over a few days, I just canceled my order. Eibach’s website says the stage one kit is out of stock and back ordered. I called Eibach directly and they told me it was actually in stock so I placed an order for the right part number. It was $40 cheaper than anybody else and it’s getting shipped from their warehouse tomorrow.
The lesson here is it pays to call and talk to manufacturers over the phone sometimes.
Whoa_Ram
Azle TX
Glad you got it worked out.
djevox
MD
Thanks for the suggestion, and I have the husky ones that other people here like getting delivered Wednesday.
djevox
MD
Thanks! If Carli had that commuter kit out, I would’ve ordered it. I called them and they said maybe February. In the end, this truck will never see off-road so I just want something that’s comfortable.
U
User_67930
Guest
How much cubic foot of air space is in that box?
  • Nels
