djevox
VP of Creative Thinking
MD
Just got the wheels on. Pictures don’t do justice on the awsome convex look of these wheels. My truck definitely needs a lift (it has a reverse level right now). Hopefully Real Truck’s resolution department gets the right lift kit for me from Eibach quickly.
Wheels: 22x10 -19 offset Fuel Contras in black/machine finish.
Tires: Toyo Open Country AT3 LT 285/50/22. 33” tall and 11.5 wide.
My wallet: 😥
1lowcab
Ohio
My wallet: 😥
Very nice, great wheel choice! (y)
1lowcab
Ohio
1D32319
Granite State
grogol
TonnoPro Hard Trifold Cover
Hi FLiPMaRC, I ordered a 2022 RAM 1500 Laramie with the Bed Utility Group that is being delivered soon. I am also looking at the TonnoPro Hard Tri-Fold. Did the bed rails in the Bed Utility Group cause any issue installing the TonnoPro Hard Tri-Fold? I would appreciate hearing of your experience. Thanks!
Haulindogs
I purchased a micro switch panel off Amazon. It was to large to fit in the empty CD slot in my console. I took it to a local engraving company that made me a new laser cut faceplate that allowed me to squeeze in five of the six rockers in the new panel. So far, I’m only using three of the five rocker switches but when I add the others I can have the faceplate labeled. Then I found at night I had problems locating the switches without taking my eyes off the road way to long, so I added a couple of small accents lights above the panel console that are lit whenever the accessories are on. It also matches the interior floor lighting.
Amazing93
Washed it then sprayed it with Adam's iron remover then washed it again then clawed it then put 2 coats of Adam's Graphene spray coating on. Should be good to go for winter now.
FLiPMaRC
NJ
No issues at all. It's been holding up well for 4 months. We'll see after this winter how good it is. Where are you buying from? I got mine from RealTruck
If I had to do it all over again, I may have gone with this one for just a bit more $$ ... https://bisontonneaucovers.com/coll...dge-ram-1500-back-flip-tri-fold-tonneau-cover
But I'm not sure how it will be installed with the BUG bed rails.
