2" level, 35x12.50 tires rub
You should be able to fit 35x12.5x17 with 2" level front but but check your caster values to see where they fall if you're using factory UCA's. I run Zone UCA's and i'm running higher than stock caster to move my wheels forward and away from the back of the front fender wells.
I've found 315/70/17 will rub the back of the front fender wells when turning with 2" front lift and factory caster. (+3* +3.5*), and 17x9 -12offset wheels, but if you go +4.5 +5.0* caster the gap between the tire and the seam open up nicely as + caster is literally pushing your wheels forward and away from that spot. Good to have an aftermarket UCA that offset the BJ so you can have both high caster and camber in the proper specs. (i run my camber at -0.2* to +0*)
prob not the best pic here but i didn't have any rubbing turning with with Rancho QL struts, which is basically setting me up for 2" front. These are 17x9 -12 offset wheels
Untitled by RAM RSM, on Flickr
Later on i went Kings, prerunnner style bumper and BFG KO2's in 37x12.5x17, setup for 2.5" then cranked the CO's couple of turns up for 2.75" lift. Ran those 37's hard for 12-13k miles in the dirt, i had cosmetic rub, didn't cut any metal
This is how much i rubbed offroading on 37's with a small front lift
as you can see it's just cosmetic rub and i didn't have to remove the front fender wells at all. (i cut a portion in the front because to match the lines of the bumper)
For the rear i removed the fender wells, and i'm also running 1" rear bumpstops
2020-01-04_03-39-10 by RAM RSM, on Flickr
i can turn even if the wheel is tucked in because of a rut
no rubbing runnning washes either, it helps Kings are extended travel so they're bumped 1" higher than stock in the front. Pardon i don't have a video going faster, i ran this wash multiple times that day at 60-65mph, but this is the only video that took. (my kid was filming for me :))
Back to 315's cause even with 3.92's the 6 speed trans do suck with 37's :) So currently running Patagonia MT's in 315/70/17 , so i'm back to having almost 2 fingers of space at the back of that seam :)
And nothing rubs at all
2020-08-08_06-36-28 by RAM RSM, on Flickr
That's an amazing amount of detail. Thank You! I'm jealous of the 37's! One day when I don't care about parking in the garage I want to run 37, maybe on a 6" coil over suspension.
FWIW, just installed the Mopar beadlock 18 inch wheels and I'm running 295/70/18 tires with no rub.
I have the offroad package with no lift. TIres work out to 34.3" and so far so good.
I'll add a level to the front end to get the right look. Still undecided on the best way to level the offroad package.
I was thinking about using the Zone Offroad kit that includes their control arms.
Pictures??!!
I ordered Cooper’s STT Pro 295/70R18 they are 34.49 exactly i hope they don’t rub will do the install next week on Fuel’s D579 Vector 18x9 Wheels along with the Mopar 2 inch lift on my 19 Rebel, Wish me luck!
Hey there buddy how'd it work out for you?
If I can't get a 35x12.5 to work then you've got the same Size I am thinking about
?Hey there buddy how'd it work out for you? I can't get a 35x12.5 to work then you've got the same Size I am thinking about,
Hello howsitoineh my tires were 35’s 12 wide no rubbing at all, That said all 35 tires are 34.5 almost keep in mind that 35’s 12.5 wide will rub even if you have enough clearence, BFG has tire that 35 but 12.2 wide with proper lift & right wheel it won’t rub, If you want the 12.5 wide you have to do the trimming and remove the plastic flap which I refused to do, I have sold my Rebel and moved to TRX now best of luck my friend.
