I posted on another thread about this but would like to hear from the folks who have been having the same issue.  Seems like a small percentage of us have had this issue and curious if there is a common configuration or circumstance that we may be able to narrow down.  I really like this truck but if I cannot get this figured out I will be switching back to another brand.  My truck is a 2020 1500 Laramie Crew 6.5 box non air ride 5.7.  So far I have upgraded to 10 ply tires and a Hellwig sway bar, both of which have helped somewhat but not  100%.
Before someone throws out the improper tongue weight or setup statement, this is NOT the case or problem.  I have extensive experience towing loads commercially, tongue weight is correct, trailers are level, truck squat is level, hitch is solid, no extended hitch, etc.  Have towed two of my own trailers and also a friends trailer, all somewhat different configurations but all newer and it good order so not a trailer problem.  They are all enclosed cargo or snowmobile trailers which do have more side area for wind to push.
Basically what happens is any little cross breeze, passing car, or other small wind disturbance, the trailer pushes the rear of the truck to the side, it’s almost as if there is enough give somewhere to allow the trailer to gain a touch of momentum, enough to give the truck a shove and push the rear off center.  Then it hits the limit of movement and rebounds back.  You can feel it seat of the pants and visually see the truck flex off center.  Its enough that you have to counter steer a little, and is downright dicey on icy or slippery roads.  It makes for an uncomfortable ride and not much fun having to be on your toes fighting it, especially if it’s a little windy.  Passengers have commented on it and my wife almost gets motion sickness from it.
I am going to try a few more things but getting a bit frustrated with it, have owned both other brands of truck that did not feel this way, my previous 1500 Chevy towed the same trailer without this issue.  I dont know if it’s this configuration, or the coil over suspension, or something that didn’t get done or tightened up on a few trucks but would like to see if there is correlation with others.  Thanks for any input.
