MurphBigHorn
- Jun 25, 2021
Correct I left the stock UCA’s for now and it’s a non ORP. I’ll buy UCA’s once I buy my coil overs.Stock UCA? None ORP?
MUCH better looking than the emergency yellow caps from the factory!Yesterday I installed the Bullet Tech underhood dress-up kit I ordered during their 4th of July special. Washer fluid reservoir cover, coolant overflow cover, brake fluid reservoir, A/C high pressure port cover, oil dipstick handle and oil cap.
the parking lot was a little slanted but it’s about perfectly even.
@AdamChandler Just wanted to point out something. Those triangles at the front of the bed are braces for the sides due to the tail gate, and are part of the multi-function tailgate package (MFT). Apparently when you use barn door function the sides may flex so they added the bracing. Not part of the BUG, but can probably be used as a lightweight tie down point.YEP and the thing was clean that morning. He sheds like a beast. I move the couch once a week and there's a whole dog worth of hair to clean up. It's a full time job year-round, not just int he spring. I've told the wife we really need to start shaving him every spring because that's when it's the worst.
This is the 6'4" bed, the bike length is deceptive because I'm losing a few inches thanks to this - https://www.motoprohq.com/truck-systems Because I have the bed utility group, I have this extra triangle on each of the 2 forward corners so my dirt bike rack sits further back
Your WR is 85.6 inches and my 701 is 89.8 inches so I've got like 4 inches on you (that's what she said) and my rack is pushed back like 6" due to the BUG triangle things so even with a 6'4" bed, I have 2 choices, I can leave it as seen above and drop the tail gate OR catty-corner it in where I chock it on the left and then swing the rear tire around and strap it down that way. It moves a little bit more sideways but at least the tail gate is up.
Shoot, I knew someone was going to ask for them and I already had Amazon opened but thought maybe not..anyway shame on me but here they are:
https://www.amazon.com/gp/product/B07YX83LKG/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
Just get the surface super clean, I didn't do it perfectly but it's just a guy who has cut these to fit our trucks. material is pretty cheap but I'd imagine you could buy a sheet of this for cheaper, test fit with painters tape then cut to size for about half the price. Anyway, it works well and the dog does scratch it as he climbs up in so for his entry/exit, it's pretty good system to have that + the dropped fabric from the bed there.
I need one of these! My daughter puts her feet up all the time too.Forgot to add earlier. Wife bought these seat protectors for me today I guess she’s tired of me yelling at my little boy to keep his feet off the seat. Haha![]()
Somebody cancelled at the tint shop, last minute, got 20% all aound today. Almost done for awhile.....needs some loud pedal.
Yes, once it's on the platform you just secure the pegs, tighten them down and you're off.That's a cool device! The jack just clamps the footpegs? That's enough to keep it from shifting left to right (driver side to passenger side)? Do you use a strap like in the video? Not sure where near the clutch cable he was placing it, and not sure why he did it.
I'd need to check the jack weight limit and the hitch weight limit. My WR250R weighs closer to 300 lb than 250 lb, and it's a 4-stroke, not a featherweight 2-stroke.
I have a skid plate on mine and I've never had it on an engine cradle or stand before. I'd need to confirm it will sit like that.
500 EXC-F, the brass ring of dual sports! Well, I like the 690 Enduro also. If only I could afford a stable of them. I'll get by with my WR250R for a little while longer.Yes, once it's on the platform you just secure the pegs, tighten them down and you're off.
I do use a tie down for the handle bars, but it's not necessary.
It doesn't wobble or shake in the least.
I ride a KTM 500 excf, 4 stroke monster and I have no issues.
They do have an HD version too, I think.
Tight fit!!Quite a bit since Friday I suppose:
1) Picked it up at the dealer, CEL came on the day I bought it and it has been sitting there waiting on parts for a month
2) Added a Sentry CT. I'll post a quick mini review. I give it a B (not a plus, not a minus, just a B) for fit and finish
3) Spent half a day messing with my builder grade three car garage (less than 600 SF) to fit three cars in it in a manner where my wife can still get the kids into the car seats
