I changed my order a week after I had my VIN and no issues, I'm in D status as wellI tried to modify my order and was told that it wouldn’t let my dealer make the change- I’m in “D” status with a vin. If you try and succeed let me know. Thanks.
I was specifically told by Mark that my order could not be changed or modified. Also, how do you check this "D" status? Through the dealer or by calling ram chat or some other way??I tried to modify my order and was told that it wouldn’t let my dealer make the change- I’m in “D” status with a vin. If you try and succeed let me know. Thanks.
I was told something slightly similar when I inquired about a color change which was just that changes are usually rejected by the factory.I was specifically told by Mark that my order could not be changed or modified. Also, how do you check this "D" status? Through the dealer or by calling ram chat or some other way??
First of all I'm new to all this too. I checked with ram chat the other day (Knowing full well nothing was happening with my order but wanted to check out ram chat)I was specifically told by Mark that my order could not be changed or modified. Also, how do you check this "D" status? Through the dealer or by calling ram chat or some other way??
Yes, I did 3 weeks after I go vinQuestion for the gallery. If you have an order already and have a vin and want to add a item like the multifunctional tailgate would you be able to add it.
If the Ram has not been scheduled for production, changes are allowed.Question for the gallery. If you have an order already and have a vin and want to add a item like the multifunctional tailgate would you be able to add it.
When I went through the order process, I was able to order the non-etorque Hemi in the Limited trim. I still have that build sheet from the dealer. But, you CANNOT get the standard Hemi if you want the 10th Anniversary Edition. That only us offered with the eTorque or Ecodiesel. Which is how I ended up with an EcodieselThey’re calling it the standard “vacation shutdown”, but I have it on good authority that the 2022’s WERE scheduled to start right after the planned shutdown. Nobody really knows when the 2022’s will actually start.
I am not aware of any major changes to the product line that would necessitate retooling, so would suspect that they can roll into the 2022’s fairly easily (some different parts go in, of course, like the Uconnect5 modules).
By the way, I see that you’re listing a 2022 Limited without eTorque. From everything I’ve heard elsewhere, I was under the impression that this configuration wasn’t available. Have you confirmed that?
If it's a sold order, you can get a regular hemi. If a dealer was ordering for stock or just pricing one out, only the etorque is available. At least that's my dealer and I discovered during the ordering process.By the way, I see that you’re listing a 2022 Limited without eTorque. From everything I’ve heard elsewhere, I was under the impression that this configuration wasn’t available. Have you confirmed that?
FWIW When I ordered 6/18 (hopefully it went in then!) I could and did order a Limited without eTorque.By the way, I see that you’re listing a 2022 Limited without eTorque. From everything I’ve heard elsewhere, I was under the impression that this configuration wasn’t available. Have you confirmed that?
Ha...I can't wait...the excitement is killing me.Ok, it's Monday, 7/26..plant should be open and building ALL the 2022's, who's got a window sticker?! LOL
I figure there isn't much point. Bothering them won't make it show up any faster!!Has anyone reached out to Mark Dodge yet today to ask if they have an update? I don't want to bombard them.
I checked and my status is the same as well. I try not to harass ram chat...maybe just one a week..lolAs I figured, checked with Ram chat this morning and still gathering parts.
