Center Console Slider Swap (Rebel to Limited)
scottmoyer
You don't need a pry tool. At the separation, just try gripping the top section and pull up to start the separation. Once you get the back started, you can start pulling up on the sides and the entire top will come off. It's very simple and no tools are needed to separate.
forrestgump
I have a Built to Serve console slider I am interested in trading for a Limited console slider. If anyone would like to make the swap, please reach out to me!
scottmoyer
What does the BTS console slider look like? Is it the same as the Rebel?
scottmoyer
For anybody looking for the Rebel center console slider, my original is available. I posted it in the classifieds. Thanks
Pjmracing152
These parts are off backorder from what i was told. Mine should ship out next week.
RiggerRoy
So, I had been eyeballing this as a possible modification for quite some time and was unsure if it was possible. I posed the question but no one really had an answer, so I just up and did it.
I swapped the sliding center console cupholder/tray compartment in my Rebel for a Limited compartment with the covers. I think it looks alot more finished, initially I intended to wrap the wood grain finish with something similar to a pattern inside the Rebel, but after installing it I'm going to leave it be. I think it meshes very well with the 12A black package.
Anyway, for those interested - The existing cupholder is removed by popping the front two retaining pins out from underneath the compartment. This is by far the hardest part. I used my phone reserve camera, light, and a set of needle nose pliers to push up (towards the roof) from underneath on the front two white retaining clips. From there I was able to grab the top portion of the tray and pull it up and out. From there its super easy, just unscrew the six screws and remove the bottom portion of the slider tray and pop in the new one.
Parts needed:
5YE132X7AGAccess Cover$496.0
6LY66TX7AARetainer-Floor Console$26.74
Overall, worth the mod I think. The replacement sliding compartment is crazy expensive in my opinion, worth 500 bucks ? That's up to you. I have my old one for sale if anyone is interested and needs a new one.
I always wanted to do this on my Rebel when I had it. This should be a factory option. Maybe with the carbon fiber look Rebel trim instead of wood to keep the cost down. It probably sounds crazy, bit it's one of my favorite features on my new Limited. It just looks so much cleaner. Nice work!
MannyN
Just installed mine. Took 6 weeks to get here, very pleased with the outcome.
Nismofreak
Do you have a photo showing where to Pry? Just wanna be extra sure before I yank this out.
MannyN
There is a photo 5 posts above yours. It shows the exact location of all the tabs. They are tight, you need to pull with some force.
1awesomelaw
Parts needed:
Is your seat that close to the steering wheel ?
Redfour5
Parts needed:
What? And give up two of my 15 cup holders?
mk2019ORP
Looking to do this and want to make sure I have the right parts. Going from Laramie to Limited are these the correct part numbers? Thanks!
5YE132X7AG
6LY66TX7AA
riveralg79
Is the Built to serve any different, I’m envious of the lock box in there.
