Air conditioning Hack
Scram1500
Using the left center stack as a guide, outside air speed 4, it went from 52 (open) to 42 (closed). Adjusting the ball valve is a little touchy but at around 95% closed I still get some heat on chilly mornings and 44 at the vent
theblet
don’t have hose pinchers, but I’m about to test this with a pair of small needle nose vice grips. we’re in the 90’s here and had the AC on full blast for at least 20 minutes to be comfortable today.
Would that work?
brian42
San Diego, CA
That would work, but be careful.
You are already degrading the hose (however slight) by crimping it. Depending what jaws are on your Vise Grips you might damage the casing of the hose.
If you are going to test it out with the Vise Grips I recommend using a rag around the hose when you clamp it to make sure you don't cut or damage the hose.
Just my .02
theblet
This is what I did. I see what you are saying. I will get something like a rag to protect the hose. The AC was ice cold this morning during my drive. However, it was only 81 degrees. 72A8B084-1BA2-4F6F-9387-8D31DBBD42A0.jpeg
theblet
Just my .02
Understood. I just checked and there are some teeth marks on the hose. I wrapped it in a rag to be safe.
brian42
San Diego, CA
My A/C loses its luster starting around 75F outside if the sun is out. :(
socalboy951
Why would they charge $100 for a TSB service even if they deny it? I use the clamp and take it off in the winter, reinstall in summer. Not a big hassle as I check air filter etc. at the same time. Not worried about hose failure at all.
what kinda clamp u use can u post a pic???
theblet
I just made my own too. My truck goes in on June 29th. Using the valve until then, but gonna take it off before bringing the truck
UnloosedChewtoy
5thGenRams Supporter
South Dakota
That is the same valve I purchased. Supposedly all steel. A bit more work to open/close, especially partly open/close, compared to the quarter turn ball valves, but still minimal effort.
I am sure I am being nitpicky, but the side effects I've heard that HOAT or our OAT coolant can have with brass makes me wary of the brass valves for this "hack." I've never heard of any of us having any issues with it, to be clear, but there may be a reason why the little turn-style valve sold at auto parts stores is steel rather than brass.
But I'm probably just overthinking it.
theblet
Yea I agree. This valve is listed as “heater control valve” at the store so it’s made for it.
1500DFW
I did my own, but I would have bought this if it was available at the time
I bought this off Amazon. Little pricey but not too much more expensive than to buy everything at Home Depot especially since I didn’t need extra hose or clamps. Took 10 mins to install. AC works great now in this Texas heat. Prior I would be sweating while driving.
dts828
Atlanta, GA
Well, I just noticed my advance auto valve is leaking at the stem. How disappointing. Not even a month old!!
Been using this one for close to 2 years without issue.
