Maxx102
So no drilling is required and you remove the rubber pad. I just put mine in the glove compartment.Did you drill through both the rubber and plastic? Any chance you could get a pic of it mounted into the dash?
The mount included two long screws which you will use to mount it using the factory hole locations.
The bottom of the mount also has that super sticky automotive grade adhesive from 3m. Just remove the red backing paper and line up the mounting holes on the mount to the factory holes on the dash and tighten it down. Don’t over tighten it however otherwise you will strip the hole out.
it does come with two short screws which will require you to drill. Using these is optional and completely unnecessary if you only plan on mounting a couple of phones or theIr GoPro mount. Tablet / iPad i can’t comment as I don’t have one and don’t plan on using one at that location.
I hope this helps.
