alacombe
 - Apr 15, 2018
Your suppose tooI have the bighorn with level2 package and nav and I have the theme options.
I have the 8.4 nav and have the exact same issue with the instrument cluster defaulting back. Also every once in a while my Sirius presets and tool bar setup at the bottom will revert back to default. So aggrevating. My dealer looked at it and sent the info to Chrysler. Just waiting for approval to replace the unit.
Just picked up my 2019 Ram 1500 Lonestar 8.4" screen with Nav a couple of days go, I noticed the exact same issue, if the truck is powered down for any length of time say > 3.0 hrs it goes back to the default setting on the instrument cluster but NOT the 8.4" display. No matter how many times I change it it will always default back to factory. Another issue I notice , when the display is powered up if you select the UConnect Apps icon which launches all the Apps, the Send-n-Go, Users Guide, SOS, etc show the U Connect Icon not their own icon, that takes about 2 minutes to populateIs anyone having trouble with the themes for their touchscreen/gauge cluster? As you know the theme can be changed with different colors and fonts etc, which changes on the gauge cluster as well. When I change the theme, the touch screen stay on the one I wanted, but the gauge cluster reverts back to the factory setting. It will stay on the theme on wanted for a day then changes back to the original. Not sure if this is a glitch in the system or what.
If you have the Laramie you have the memory seats function right? It seems that if you pick what you want and save it to driver 1 memory that this issue goes away from what I've read on here. I thought it was looking like only a big horn with nav problem. Be interesting if you have that option to save everything and then try to duplicate the problem?Just purchased a 2019 Ram Laramie, having the same issues with the Theme and the cluster reverting back to the factory setting.
Yes I have the memory seat function, I will give that a try and keep everybody posted.If you have the Laramie you have the memory seats function right? It seems that if you pick what you want and save it to driver 1 memory that this issue goes away from what I've read on here. I thought it was looking like only a big horn with nav problem. Be interesting if you have that option to save everything and then try to duplicate the problem?
Bighorn, Level 2, W/O Nav. No Nav = No Themes... seems to be a recurring Theme... No pun intended.I have the bighorn with level2 package and nav and I have the theme options.
The last couple of days I have re-programmed my seat memory a couple of times, the problem still exists whether I use the auto start button or get in the truck and manually start it, it reverts back to factory settings.Yes I have the memory seat function, I will give that a try and keep everybody posted.
Interesting, thanks for checking, it seemed like sort of a gray area until someone confirmed it. I'm sure its low on the priority list but it should be a simple software update at some point.The last couple of days I have re-programmed my seat memory a couple of times, the problem still exists whether I use the auto start button or get in the truck and manually start it, it reverts back to factory settings.
I just got my Laramie black 2 weeks ago, and I have the same problem. I can set I to the blue, Limited color, but do not get the blue rings around the cluster gauges.I can get my 12 in screen to show red ( from the blue color ) but no change to the gauges.
