redneck
s.w florida
yes took the neg cable off like the book said to i have started it 3 different times & no change also i have no options to change anything in the settings menu when i touch lights or camera the screen is blank no options is that also normal
vincentw56
Yes, it is all normal when you disconnect the battery. It can take a few hours for everything to come back.
2020 Bighorn Night Edition, 5.7 Hemi w/eTorque
Idahoktm
North Idaho
YELOSUB
What made the hooks such a PITA to remove?
If you have access to a lift or if you remove your front air damn it would be much easier...I didn’t do either...I scooted underneath the front end and had very limited access to the bolts on each side...They are on there VERY TIGHT! I didn’t have a lot of leverage but managed to get them loose...The long bolts are a little tough to bang out due to the retainer piece that you destroy and don’t reuse...Install was much easier..:
redneck
s.w florida
wow it took 4 hours for my truck to start working again after un hooking the battery lost some programed stuff but the seats & radio stations stayed also the lie-o-meter now says i LOST 4 mpg on the interstate cruise set at 80 mph =14.4
U
User_63152
Guest
"lie-o-meter" :ROFLMAO:
GATORB8
Charlotte, NC
I tried from underneath, it’s helps a lot to pull the front liners from the wheel wells. Regardless those bolt retaining washers are a PITA. I used a 15” adjustable wrench with a dead blow to yank them out.
GATORB8
Charlotte, NC
Rewaxed the hood and fenders after doing the whole truck last week. Lots of contaminates on the hood, and it was still holding dirt.
I normally use clay, but I was out and all I found locally was the Griots Synthetic Clay. Holy crap, I’ll never use normal clay again, the synthetic is sooo much better.
Brought it back up with Megs Mirror Finish cleaner wax.
Idahoktm
North Idaho
Well that's good. My truck doesn't come with hooks, so I was thinking about adding them.
U
User_63152
Guest
Got my new wheels. Have an appointment at 10am to have the put on. Super excited!
I will show them after the install. :cool:
