Front Skid Plate
Rsorrell2
Chula Vista CA
I would contact them and ask but I would think that it would as the Rebel frame and the 1500 frame should be the same.
MurrayB
@MurrayB - Possibly a stupid question: How did you mount this to the front bumper? Are you using bolts with threaded spring clips, or are you managing to get washers and nuts in behind the plate (which seems like it would involve a lot of swearing...)???
There was enough room in the little pocket of the front bumper to drop in a small washer and nut and tighten with a small 1/4" drive socket. Surprisingly little swearing during install. I haven't had to take it off, though.
Rsorrell2
Chula Vista CA
Thekidcasual very simple and easy install really.
hardest was loosening the existing nuts/bolts.
i used a floor Jack to hoist it up into place so one might need a second person.
but the fit was perfect
taylorashipley
I'll definitely be keeping an eye on temps in the short term. 103 out today and no issues.
I should have mentioned it's for a '20 1500 Lonestar (Big horn). The plate started out as a 27" x 28" sheet. Its 27" across at the bumper and tapers to 19" at the crossmember. Excuse the crude drawing...my big template with the numbers got trashed.
way behind on this but looking to do something similar to this for my truck. How does this mount to the cross member? I easily see how you mount it to the bumper... can you post a pic of how it mounts on the other end? Thanks!
BUFFRAM21
How far forward does it go? I'm looking for one to cover the gap between the front bumper and the crossmember. Thanks
theblet
Is there a skid plate which will work with the air dams still on the truck?
Rsorrell2
Chula Vista CA
Ma1enemy if you looked at the photos they have online you would have seen that it does not go all the way to the bumper.
i have not found anyone that sells one for that area, but I am happy with the Dethloff one as it does protect a very sensitive area.
Shifts And Grins Fab
5thGenRams Vendor
5thGenRams Vendor
Gilbert Arizona
If I was to design and manufacture a full bell skid in multiple peices, who would be interested, what pieces would you be interestered and what would you be willing to spend? If it is worth while I will design and offer a full belly skid in pieces (probably about three pieces) and make it available to purchase all or just pieces. Let us know.
Eltaco
I think a lot of us are looking for a skid plate to cover the area between the bumper and lower control arms when the front air dams are removed from the truck. Nobody makes this accessory now, so there’s no competition for you if you do it. Even better if you can make it with some aesthetics so it’s not literally a flat plate with a few connection holes in it!
JbVt
Exactly what he said!
RamMe
I’m in if a package is available.
cervelo15
Lehigh Valley, PA
I'm in too, if it's setup to cover from lower bumper on back. That air dam looks hideous, so I dont want to take it off unless I have some protection under there.
