Look niceI did paint the rings & am happy with the results
Looks fantastic. Great job man!I did paint the rings & am happy with the results
It touched barely but it’ll mess up things without a spacer, i can’t wait to see yoursI saw this new Rebel at the dealer today. Dealer upgraded with TRX wheels/tires and Fox coil overs sitting on the lot.
It looks like the tire flexed enough on a corner to rub on the upper control arm.
Thanks to this forum, I’m waiting on my BORA wheel spacers to arrive before installing my TRX take offs.
No way it would just be another 1/2” away from the upper control armIf I get a 2 inch space for TRX wheels, would it rub the upper control arms?
Where are you at i now have two Bora 1.5” spacers extra since they take so long.I’m still waiting for my Bora spacers, hopefully they arrive soon.
So the tire is rubbing on the control arm, isn't that bad?Here’s a few pictures for ya & the upper control arms touching i ordered Bora 1 1/2” spacers for the front
are you aware that the stock upper control arm is re enforced plastic with a metal cap on top. try sticking a magnet to it underneath.I saw this new Rebel at the dealer today. Dealer upgraded with TRX wheels/tires and Fox coil overs sitting on the lot.
Yes i wouldn’t drive it like that so 1.5” spacers fixed the issueSo the tire is rubbing on the control arm, isn't that bad?
TRX has a wide body kit which won't let the tire rub. Can't find that on the market at this momentMy Bora 1.25” spacers arrived today. The tires stick out a bit more than I thought they would. I had rubbing on both sides, a little on the passenger, a lot on the drivers. Some massaging with the heat gun fixed it for now. View attachment 92805View attachment 92806View attachment 92807
The wider trx suspension also moves the tires further out from the body. Between the suspension and wider fenders, the TRX has plenty of room!TRX has a wide body kit which won't let the tire rub. Can't find that on the market at this moment![]()
Please post the pics after you have hime leveled! All the best!The wider trx suspension also moves the tires further out from the body. Between the suspension and wider fenders, the TRX has plenty of room!
I’ll be getting a leveling lift soon, and that will help, after the heat gun treatment it’s not hitting any longer. At the angle the wheels are turned when it rubbed, it would be unlikely to rub with the lift, unless rock crawling which I won’t be doing.
Looks great i also had to do the fender liner mod and have a maybe 1 1/2” front @ back revel links to lift and it never rubs even in Aero mode i can use entry/exit too but no turning then it would rub but it’s good for loading & unloadingMy Bora 1.25” spacers arrived today. The tires stick out a bit more than I thought they would. I had rubbing on both sides, a little on the passenger, a lot on the drivers. Some massaging with the heat gun fixed it for now. View attachment 92805View attachment 92806View attachment 92807
TRX suspension is 3” wider on both sidesThe wider trx suspension also moves the tires further out from the body. Between the suspension and wider fenders, the TRX has plenty of room!
They look great , sticking out doesn't look all that bad really.My Bora 1.25” spacers arrived today. The tires stick out a bit more than I thought they would. I had rubbing on both sides, a little on the passenger, a lot on the drivers. Some massaging with the heat gun fixed it for now. View attachment 92805View attachment 92806View attachment 92807
