Floor lighting to ambient lighting?
Daverous
Reminds me, what pins did you guys use to add the under seat lighting? Tried some dupont I had but they didn't work for either side.
Speaking specifically about yellow under seat harness and under seat led pictured. Bought all the parts but struck out yesterday when I realized I didn't have the right pins.
Amerinamese
So, my foot well lights are always on. Are they not supposed to be? I don't know how to turn them off.
AnvilBTS
My footwell lights are always on as well. They do dim with the dash lights and the overhead console lights. I cannot turn them completely off which I would like to. I only have one dial next to the headlight switch not 2. Any suggestions other than removing the footwell lights?
securityguy
North Florida
I have the dual switches in my Limited and I can completely turn off the ambient lighting (footwell, dash and door panel) lighting.
daze513
Any chance anyone can tell me the full parts list for adding only the rear footwell lighting that goes to the white tab with the 2 holes mentioned earlier?
Tried to follow along on the thread and got lost.
2020 Big horn level 2 with 1 Dimmer wheel, and front footwell and overhead LED lightning.
Rick Rebel
--- in your pic, if you notice the large yellow plug... the new light assembly will be wired to that... I can give you the pin outs to each side once you get the parts.. You will only need to re-pin two cavities but three will be used... the common ground will be re-used...
-=FM45=-
Hi FM45:
waiting on your response, as I have a 21 Rebel with the led footwells in the front, and adding LEDs to the back (under the front seats). I have the OEM rear LED lights and connectors? how do I tie into the "yellow" connector under the seat so they work exactly like the fronts? Thanks in advance!
FM45
MA
@ Rick--
Parts needed--
@ Under Rear Seats
OEM 68367033AA qty2 Lamp Foot well Rear LED
Mouser 571-1456983-1 qty 2 Connector
Mouser 571-1670144-1 qty6 1.2 Terminal
@ Yellow Plug
Mouser 538-33000-0003 qty4 Male Term.
Mouser 538-33012-2002 qty4 Female Term.
Use this site --
look for--
Lamp Footwell Left Rear
Lamp Footwell Right Rear
XY410A x2 (yellow plug Left)
XY420A x2 (yellow plug Right)
Run two 22 gauge wires from exiting led front foot well, one from the interior and one from the ambient side... they will go to the yellow plugs under each seat and wire them per pics on the connection site... when wiring the leds under the seat, you will be using three wires but only pinning two, the third will be tied into the exiting ground in the yellow plug(s)---
If needed I can try to dig up some pics---
-=FM45=-
Rick Rebel
@ Rick--
Parts needed--
@ Under Rear Seats
@ Yellow Plug
Use this site --
look for--
-=FM45=-
Thanks! great info....note I'm not electronically savey, but I can follow instructions well :). So i'm a bit lost. I have the OEM rear lights and plugs (three wires already attached to them, yelloe, wt/grn and black)
Rick Rebel
sorry....hit the key too fast....anyway, are you stating that I need to run the wires from the front footwells ( under the dash, on both sides?) to the corresponding front buckets ( yellow plugs, left and right), then run the wires from the new leds to the yellow plugs? trying to follow along....Pics would be nice! thanks for your patience.....
FM45
MA
Now I'm at a loss--- you already have everything in place --- did you add them or were they already in place from factory..
If they are already there they should work as is... yellow is interior, wht/grn is ambient, and black is ground... Are the yellow plugs populated with the corresponding wires .... PM me and we can get into more details....
-=FM45=-
Rick Rebel
-=FM45=-
Sorry, no I got the lights/with connectors, I haven’t installed them yet, I see the white plastic pieces the hook up to unfortunately I don’t have the clips (and you can’t buy the separately according to the dealer), I was originally thinking I just need to run the wires from the new lights (under the seats) and tap them into the front lights (under the steering column and passenger glove box), and boom I’m done! Then I read this thread...and threw me for a loop (thinking this way is cleaner and less fishing of the wires) I also had a peek under the seat and I do see the yellow plugs, I don’t know if the yellow plugs have the required wires already there, I’ll have a look tomorrow, I know manufactures sometimes have everything already there, just not activated. Again thanks for all your help👍
ramButz
syracuse,ny
i had to take my doors off.so while i was at it,i decided to add some little "LED"lite strips.worked for me.i know it looks like "Hell"its why i had the wires with different colors.i made a note. which color for which :LOL:..but it worked👍
Rick Rebel
Nice (y), wanna get there eventually, but right now I want to get the under seat ambient lights working first!
FM45
MA
Rick-- Posted is the yellow plug being refereed to... this is the one from pass seat - drivers has the same ... XY410 and XY420 - locate them and check what wires are present or not ... as far as the leds you have in had, check the part numbers against the numbers that are posted - the posted ones have the mounting clips already present...
-=FM45=-
Rick Rebel
-=FM45=-
Cool, I just checked the passenger side (looking from the front) and the ambient and curtesy wires are there, so used some pig tails to jam them into the pins, and bingo the curtesy light came on!, now how do I tie into those pins if the wires are there? and I'm assume the drivers side would be the same? not much wiggle room with all those wires....very tight.
FM45
MA
--- that is a two piece plug.. slide the two sides apart and see what side is missing--you'll either need the male or female ends... re-pin your wires and you should be up and running
-=FM45=-
Rick Rebel
-=FM45=-
Thanks for all your help! should be smooth sailing from here, plan to install over the weekend.
Atp816
Sorry for delay... some basic wiring knowledge is required for this mod. The old light assembly and connector must be removed and replaced with the new assembly and connector. Use the reference url posted for connector pin-outs, look at lamp footwell lighting basic/premium --- the basic is a 2 pin connector where the premium is a 4 pin: An extra wire must be added for the ambient side of light assembly to operate. I added the front and rear led/ambient lighting and they work as advertised. When time permits I will do a write-up....
oem
68312665AA x2 front led
68367033AA x2 rear/drivers and pass seat
connector
Mouser # 571-1456983-3
**Mopar Connection Repair
for reference -- http://connectors.dcctools.com/home.htm
-=FM45=-
If I’m adding new ambient light assemblies and connectors to the front driver’s and passenger’s side footwell, am I understanding the thread correctly in that I need to run an additional wire to the C6 connector for the ambient signal? If so, did you tap directly into wire 7 or make the connection by another method?
also wondering if there’s a preferable way to split the feed in order to route the signal to both sides of the vehicle?
I’m installing this on a truck already equipped with the ambient dimmer and roof console led functioning.
Big3MG
Anyone know what specific settings in the BCM would need to be changed using alphaOBD to enable dimming of the footwell lights if a double dimming switch was added (I have the footwell and console convenience lights but just can’t dim them - 2020 Rebel 12)?
