Floor lighting to ambient lighting?
If you are referencing the plug behind the head light switch and dimmer, I believe all wires are present-- you leave as is.... Look at the BCM and locate C6 and see if the wire is present... If it is, I think if you change the switch to one that has a dimmer/ambient knobs and make the proper setting change with Alfa, your over head led would be working.... What part of the world are you from... if you are local I would be happy to assist you; I am in MA .... Again these vehicles use 1 wire to do multiple commands, the days of adding power or ground to a circuit are nearly over, DATA is the new game....
-=FM45=-
C6 = large white plug w/gray lock
I;m almost there; but have 2 questions. I robbed the ambient light harness from a donor IP harness. It has 6 female and 1 male pin. I'm clear on 5 of the 6 female--2 to the courtsey/ambient footwell lights and 3 to the IP ambient lights. 1. But I don't know where the 6th female pin goes? 2. I labelled the one male as going to Pin 20 of XY 370A. But you said (I think) to C6 pin 7? Thanks, Brent
So, here is my dilemma. I bought the pins from mouser, male 538-33000-0003-lp and female 538-33012-2002-lp.
They do not fit in the yellow connector, they look like they are to big.
Any inside of that?
Thanks.
Anyone know what specific settings in the BCM would need to be changed using alphaOBD to enable dimming of the footwell lights if a double dimming switch was added (I have the footwell and console convenience lights but just can’t dim them - 2020 Rebel 12)?
Did you ever get your answer? I’m adding the light switch with ambient dimmer and trying to get it working.
