CHMSL wire tap for topper
UncaBuddha
Got the top all wired up today. That wiring harness worked like a champ! Going to go camp out in the back this upcoming week and check for leaks etc.!
NorthStar
Texas
Agree! The Leer wiring harness is priceless.
TNRamGuy
Knoxville, TN
Yes, Robalo2718 you are correct. My 2021 1500 Laramie has this pigtail (white/purple tracer) capped in black shrink wrap in the exact location as Ammdrew's diagram on post#48. You only need to take off a wrap or two of the fabric tape to access--I could actually feel the end cap under the wrapping. The rest of the harness can be left alone. This makes hookup of the CHMSL super easy (just connect the ground to the frame somewhere). No need for extra harnesses and logic modules to tap into the 7-pin trailer harness. Thank you everyone for your help!
Now, to figure out where to tap into to hook up the dome light so it works in conjunction with the factory LED bed lighting...
I found the pigtail also, was on top of the frame with about 1/4" sticking out, it was not visible from below but easy to feel. It was taped to the top of the wiring harness directly above the hitch bolt.
20210310_114230.jpg 20210310_114242.jpg 20210310_114259.jpg 20210310_114311.jpg
jojo7070
Hey everyone,
I have 2020 2500 with Aux switches, turned out that the factory runs wires to the back of the truck for Upfitting.
It took me a while to find them, plus you also need to connect inside the truck above the parking brake to the grey jumper that comes with the Upfitter kit.
(*These two circuits become active when the 6 cavity Light Gray connector (Jumper por Upfitter 2) included in the Upfitter kit is installed onto the Light Gray connector at location D in the vehicle diagram)
This link should give you all the information you need to set up a 3rd break or connect lights or any other stuff without running any new wires from the Aux plugin
Campinram
So just to clarify, has anyone found this wire on the 2019's? Or is it MIA til 2020 models? I've looked and can't find it on mine.
NorthStar
Texas
My 2019 did not have it. My 2020 does have it. My coworkers 2021 has it.
NorthStar
Texas
To be honest, I didn’t utilize the pigtail even though my truck has it. Instead, I splurged and purchased the kit below which a much cleaner installation as it provided the brake light as well as power for the interior lights of the topper.
sheepdogtrail
View attachment 85279 View attachment 85280 View attachment 85281 View attachment 85282
My 2021 BigHorn EcoDiesel also has the pigtail in this same location. I will be wiring up my 2014 EcoDiesel ARE X series topper (it fits 99% of the way, which is good enough for me) to it in a couple of days. My wire I believe is just white as my eyes can only see white on something that small. But it looks exactly like this one in the pictures above.
jellis466
Missouri
I have an ARE V series with the dome light and LED strip lights that i just bought off a truck at a dealership. Where do i tap into to get the LED and dome lights working?? my truck doesnt have the OEM bed lighting
NorthStar
Texas
See Post #88 above for an easy method.
Ratfink
Has anyone done this yet? Still looking for good options while I wait for toppers to release
Well I have a 2021 RAM, built Aug 9, 2021. I purchased a Y-connector harness that tees off the 7 pin connector, from eTrailer, and converts to 4-pin pig tail. Added a 4-pin extention and ran covered up behind tail light into truck bed along with a power wire that I soldered into Aux-12 volt off the 7-pin. Ordered a $15.00 electronic connector that, connects into my 4-pin trailer harness and converts turn/brake lights on harness into brake light.
kbraunphoto
Anyone have another place that has this harness?
I can't get their site to load.
NorthStar
Texas
I tried it just now and the link works fine.
kbraunphoto
gotta love technology.... still doesn't work on my end but ill try and fight that battle another day.
Looking to make sure it works with this [see attached] I have partially installed; albeit hacked away at when the previous owner sold it to me:
Warpspider
Hello, I was wondering if someone could post picture of the wiring diagram from the
Leer Third brake light 7-Way Interface plug-in T Harness - 300100​
Installation instructions.
Thank you
Alleyesonme
First time poster
2021 ram 1500 with the lights in the bed
Just got a new leer cap with a dome light
I’ve found the white and purple wire under the truck and a good spot for a ground I think, but where do I hook the third wire up to have the dome light work in conjunction with the bed lights?
I’m assuming to the red wire that’s behind the drivers side light that has the power button
Thank you
Alleyesonme
First time poster
Thank you
CogitoErgoLevo
Los Angeles
Thanks to this thread I was able to locate the white/purple wire under the bed and wire the 3rd brake light of my camper.
The installer wanted to charge me $150 to splice the wires under the driver's door jamb to wire the 3rd brake light. I told him about the wire under the bed but he laughed at me....
Thanks again
