‘19 RAM Rebel Light Bar Issues
OkieSooner94
Has anyone had any issues when tapping into the fog lights to power a light bar and the light bar illuminating when turning left?
DenCoRam
The fogs turn on when turning left or right to better illuminate the corner. If you tapped in the light bar to them, guessing that is your cause. Not sure if there is a way to turn that feature off.
CaptainCJ35
This...
If your fog lights are off, when you turn your steering wheel right or left past a certain angle the fog lights turn on as a driving/marker light. Tapping your light bar into a fog light... I'm assuming the left one... will turn your light bar on whenever you turn with the requisite steering angle.
OkieSooner94
This...
Do you know if this feature can be disabled or bypassed?
2019REBEL
ON, Canada
Only way is to leave fog lights on then they won't activate with turn signal.
I know you looking to activate the lightbar but why don't you wire it up to a wireless switch that way you don't have to run any wires into the cab. That's what I did.
