Gitter
Texas
Was hoping to fishing up the wiring this weekend but at least the light is installed. Just need to run the power for the S2’s and then light em up!
A guy used to make some of these with BD lights in the Tacoma CHMSL and they are awesome. I have been looking for the Ram since I bought the truck...where did you get it???
Techna
Magnolia TX
Yup, gonna need some more information here. This has the mod juices flowing and leaves me questioning what sort of crafting I’d have to do transplant this or something like it onto my Leer cap.
WReckeR
Indianapolis
I'm looking for details on how to remove the OEM trailer wire harness in order to install the CURT 56584. Not sure how it's secured, and I don't want to be breaking off any important snapping tabs.
z0n3
There should just be a tab on the red clouded portion of it. Push in and pull the plug out. You won't break anything as long as you aren't yanking on it!
grimreefer
U.S. Merchant Marine
Free State of Florida
It was hard for me to see while under the truck so the easiest way for me was pushing the whole thing out through the bumper and then removing the 7pin from it. Squeeze the two metal tabs holding it in place (one circled in the pic, the other on the opposite side) and it should push through fairly easy.
z0n3
Finally replaced the hood weather-stripping push pins that I removed to install a bug guard. Just used some 3/16" panel fasteners and good as new.
U
User_63152
Guest
I had Westin HDX Stainless Drop Nerf Steps and an Extang Trifecta 2.0 tonneau cover installed.
Lookin' Sharp!
Now, I am having second thoughts about installing a leveling kit. It looks really sporty the way it is. I can still go up to 275/60/R20 tires without a level in the front. Truth is, I probably just don't want to do the work. :ROFLMAO:
Suggestions?
GrayRam20
Done this weekend....some winter fun left it a little broken....was time to fix it up.
Easy enough with the active dam removed already and lower valance, i could sit up under it basically because they dont have a belly shield on them...... think it was 10- 8mm an 6 pop clips.
DONZILLA
Lookin' Sharp!
Suggestions?
I love the Steps. Great looking Truck. I went with the Mopar Lift. Not too tall and I like how it handles.
I didn't like just leveling the front.
DONZILLA
Good job! I'm planning some chrome tow hooks for next weekends project.
NorthernArea51
NY
Lookin' Sharp!
Suggestions?
Is the trifecta 2.0 one that can flip up from the cab side as well as the tailgate side?
downsc123
Just the one tab to press in and then the connector pulls of pretty easily. Problem is the tab to squeeze in it up high (toward the 12 o'clock position) making it hard to see. Just feel for it, press in and the connector will pull off fairly easily.
