I did mine and really like it.
2019 Ram Rebel, 5.7 Hemi
Got mine in today. I really like the look. (y)
Here's mine. LOL. It looks sweet. :cool:
You can tell how damn bright my map lights are in these pics. :ROFLMAO:
I did a not so official 0-60 run. Not sure if the road was quite level, but oh well. Only did one run, because I thought I saw a cop behind me. LOL.
2021 Ram 1500 Hemi 5.7L Big Horn Quad Cab, Night Edition, 3.21 Anti-Slip Rear
4WD high, TC off, MDS off, radio off, windows closed, heat/air off, Roar Pedal on SU9 (Race 9), 89 octane, full tank.
I have a K&N drop in air filter, that's it. Everything else is stock, minus the Roar Pedal and Tazer DT (has a 0-30 / 0-60 timer function).
I'd say not too bad for a 5300 lb truck.
Gave her a bath today, hand wash, power washer spray, and now my back up cam isnt working. Just a black screen. Opended and shut the tail gate with it on and no flicker or anything. Anyone else ever had that problem?
Watch the video below and do the 2 button reset. That's what I did and no issues since.
I ordered the BAK Revolver X4s Tonneau Cover! I was going back and forth between this one and the bakflip mx4. can't wait to throw it on!
Installed my visor light bar to a keyfob harness w/ 15amp amp. I also ordered the HuskyLiner mudflaps so those should be here tomorrow to install.
got gas for the first time since i got it, math says my tank average was 25 mpg, and it got 527 miles out of indicated 3/4 tank
What is the premium you paid for diesel vs unleaded gasoline at the gas station, any idea? Plenty of folks like the improved fuel economy, but diesel is generally more expensive.
Out with the old, in with the new!
Borla S-Type (yes I love it, yes I’ll get a sound clip, no it doesn’t drone even in MDS, yes I was able to get the stock exhaust out in 1 piece - I think those are all the usual questions).
Dropped in a k&n filter. Popped out the stupid carbon filter. But Dyno said +5hp. MPG calculator says “stop gunning it everywhere”
So this happened
I have the Nilight Bed Light kit and wired it to the existing bed lights and used the supplied on/off switch as a kill switch so I could disable them if needed.
The two-sided tape let go and I destroyed the switch when hauling cargo last weekend. I decided to use this opportunity to upgrade that basic old switch.
I went with a water proof LED push button to fill that little hole by the tie down ring.
Completely inconspicuous when on.
Lit up when off.
Can you provide more info on that switch? I don't have the same bed that you do, so I'd have to look to see if I have that hole, but I like your switch.
Also, can you describe your wiring method, "wired it to the existing bed lights"?
I've been avoiding wiring up mine, while I consider how I want to do it. I would like to avoid a T-tap. I also don't know what the wires look like behind the OEM switch. The left light is the light AND the switch, for the OEM kit.
For me in San Antonio I average 26.5 to 27.5 MPG daily. My 2019 Hemi was 16.5-17.5. Even with the cost of DEF I'm still a little ahead on the daily cost to drive it. I also got my EcoDiesel In December when they were selling 2020's for a lot less. So I didn't have the up charge for the diesel engine. I went to look at a new hemi that day and it was the same price with almost the same options. Typically the diesel is about $3000 more on the sticker. I drove it back from Denton yesterday to San Antonio and still had over half a tank and I have the smaller tank.
