- Apr 22, 2018
BZ23 said:The guy at the tire shop recommended the 33x12.5 and a 20x9.5 rim. Says i wont rub. I hope he is right.
(see attachment)BZ23 said:After doing much research I have decided to get a 33x12.5 nitto Terra grappler and a fuel vapor wheel added.
Looking at the specs for the Fuel Vapor 20x9 (don't see a 9.5" anywhere...), you might want to see what offset he is planning on getting for you as there's quite a difference in the offsets offered.
The larger the number, the more the wheel/tire will be tucked under the truck (closer to the suspension). Too far in, and you risk rubbing on the control arm/other components. Too far out (smaller numbers, or even getting into negatives) and you run the risk of rubbing on fenders/bumpers/trim.
Has anyone found what the factory offset is for the DTs?
For the DS's: Stock Ram 1500 wheels specs are as follows:
Size:17x8 +25 offset (5.5” backspacing) 20x9 +19 offset (5.75” backspacing)Anyone know the bore size for the DT?
