Home | NHTSA
Get resources and info about staying safe on America’s roads. And, find out if there’s a recall on your car or how to report a vehicle safety problem.
the more reports, the more likely a fix
Reading this thread I was wondering whether the gear ratio made a difference but I see people with 3.92 having issues. Now I’d love to know if there is truly an electronic way that a dealer might know about a pedal commander or whether they’re just looking to see what reaction they get. Following...
This is probably me. I don't see an issue, but I do drive it easy for sure and this is my first truck. Still though, if a press the pedal the most delay I ever get is a half second and mine was built on 10/19 and is stock.I'm wondering why some guys claim theirs are fine, and others like me who've had 15-20 trucks over the years know that there's a problem.
I've had two software updates over the last 12 months including the newest one that is supposed to be the Holy Grail, and my truck is still as sloppy as it gets. Very non-linear throttle response and performance. If you drive it like a 90 year old man headed to McD's to get coffee you can live with it. If you drive normally it's frustrating as hell.
I can't believe that these things are coming off the assembly line totally different from one another, so obviously some guys are new to trucks and don't recognize the issue here while others who know how a powertrain should operate in a vehicle like this can instantly see the issue.
At this point I'm giving up on a factory solution. I'll wait for the GDE tune. They will actually solve the problem.
This is my first diesel, but I’ve had 10 different full sized trucks. There is definitely a noticeable lag. I didn’t bother taking my to the dealer. I also am waiting for the GDE tune.I'm wondering why some guys claim theirs are fine, and others like me who've had 15-20 trucks over the years know that there's a problem.
Exactly that. You know you’re having a problem. Across any brand there are inconsistencies like this. Same thing with the 18 Ford I had. Some people had same issues as others, some did not. The majority of the trucks could be fine but with so many being built a small percentage becomes 1000’s of trucks not making it out like the best of them. Sucks you guys are dealing with this. In a perfect world they would all come off the line perfect but beer time gets close and whoops! Hopefully GDE gets you dialed in. I can only imagine it will be night and day better with how well their tunes have been for eco diesels. If that doesn’t get it right, maybe there’s a bad batch of parts in the mix. Your guess is as good as mine. If it was bad enough I’d want a do over.I'm wondering why some guys claim theirs are fine, and others like me who've had 15-20 trucks over the years know that there's a problem.
The newer trucks these days are built for efficiency so the factory filter shouldn’t be chocked up in stock form. The eco boost Ford’s had around 500hp worth of flow. 5 star recommended nothing other than their tune.Has anyone tried an aftermarket air filter or an AEM drop in filter?
I have had several vehicles, including a turbo that had noticeable throttle response improvement after I removed the paper OEM filter.The newer trucks these days are built for efficiency so the factory filter shouldn’t be chocked up in stock form. The eco boost Ford’s had around 500hp worth of flow. 5 star recommended nothing other than their tune.
Is the K&N a drop in filter or did you change out the FIPK?RP, i have a K&N air filter and it did pretty much no better than stock. kept it only because of the reusable factor being able to clean it yourself.. The lag in a 50K truck is not acceptable. had it flashed a few times and did really nothing. reset pedal few times, did not that much.. Pedal Commander did help but threw codes and ABS, Traction control light, no 4x4 light and so on.. PC said to install the update and i was done with them and decided to order the banks pedal monster, which is on the way. I will report back to the brothers good, bad or indifferent.
From what I have read on this forum and others have commented; if you do not remove the charcoal filter you will not realize any difference with the K&N drop in filter.left charcoal alone.. kn was same exact fit as oem
awaiting gde tuneThis is my first diesel, but I’ve had 10 different full sized trucks. There is definitely a noticeable lag. I didn’t bother taking my to the dealer. I also am waiting for the GDE tune.
I also have a 2020 Ram EcoDiesel 4X4 which I purchased in November of 2020. I've installed the Throttle Commander as well but that doesn't help when it cold and your taking off from a standstill or sometimes from a slow roll the truck simply doesn't react to the throttle input, this almost cost me a really bad accident I couldn't get out of my own way to vehicles had to dodge me a take evasive action to avoid running over me, it took what seemed like 2-3 sec before it final accelerated than it about snapped my head off.I've had my 2020 Ecodiesel for about 6 months and overall I really love the truck. The styling, interior and ride are exceptional, however I absolutely can't stand the lack of throttle response from a standstill. Response is just fine from a rolling start or at highway speeds but it's really bad from a standstill, especially when the engine is cold. I actually think it's dangerous at times too. I have a pedal commander installed but it's just a bandaid and FAR from a cure. There is a ton of discussion about this issue with the gen 2 engine, however not a lot on gen 3. How many of you are having this issue? Any solutions / workarounds? Any news of a GDE 2020 tune? Looking forward to hear your thoughts. Thanks.
Any news about the Banks Pedal Monster? Did it work?RP, i have a K&N air filter and it did pretty much no better than stock. kept it only because of the reusable factor being able to clean it yourself.. The lag in a 50K truck is not acceptable. had it flashed a few times and did really nothing. reset pedal few times, did not that much.. Pedal Commander did help but threw codes and ABS, Traction control light, no 4x4 light and so on.. PC said to install the update and i was done with them and decided to order the banks pedal monster, which is on the way. I will report back to the brothers good, bad or indifferent.
