WRH
- Jul 11, 2018
I installed a Cerwin Vega amplified sub. Sounds great.... Until you drive the truck. The ANC is causing the sub to put out all kinds of crazy noise. I used speaker level inputs to the sub from the b-pillar. I just figured out this afternoon what was causing it. I even went and ran heavier wire for the power and redid the ground wire thinking it was interference. I don't want to take everything out. That's why I'm hoping that if I relocated my wire taps to the input harness I'll get the signal without the noise produced by the ANC.
You are correct. Remove the ANC and tap the incoming radio inputs. That should fix your issue.
