Chris3058
Nope. Stock as stock can get. And they are on back order. So maybe they are replacing lots of them? I dunno.Lift or leveled?..
Remote start on my truck still has issues some days, it was only -4C yesterday and it did the usual one light flash/horn honk. I’m pretty sure there is either a module drawing power or my battery is no good. I drive plenty of miles to keep it charged up, 32000km in the first year.Yup I'm loving the update. Remote starter my truck in -25 Celsius the other day. No block heater or anything. Fired right up and went into high idle.
I took all my grounds off and cleaned them. That seems to have helped.Remote start on my truck still has issues some days, it was only -4C yesterday and it did the usual one light flash/horn honk. I’m pretty sure there is either a module drawing power or my battery is no good. I drive plenty of miles to keep it charged up, 32000km in the first year.
Truck is in for “Hard Start, Remote Start hit and miss, and loud fan running after driving”
Let’s see what’s happens.
Under "Cause" for section B it says 18-008-21, which is the TSB number for the update, so hopefully that means they did it.![]()
Ok... So did I get the update?? Who can read this thing???
The thread title is 18-008-20 -- this guys TSB ends in 21 on his receipt... interested to hear/see what ELSE is included in the TSB ending in 21 vs. the one in this thread.Under "Cause" for section B it says 18-008-21, which is the TSB number for the update, so hopefully that means they did it.
If you look at Post #8 in this thread it shows a screen shot of TSB 18-008-20 Rev A. I’m not sure if 18-008-21 is a new TSB or if Ram just renamed 18-008-20 Rev A. I could not find 18-008-21 in the NHTSA data base.The thread title is 18-008-20 -- this guys TSB ends in 21 on his receipt... interested to hear/see what ELSE is included in the TSB ending in 21 vs. the one in this thread.
I've noticed that with the shifting as well, shifts seem a bit more firm/quicker than they were before. I've also noticed the shifting into 5th or 6th between 25-30 MPH, but really only see it when leaving the neighborhood in the morning so it doesn't bother me. I'm wondering if the shifting will change at all as the new programming adjusts to my driving style.The more I drive the truck post-update, the more I realize that the thing I dislike the most is the trans shifting. It's a little rougher on the 2-3, 3-2 shift now. And on cold mornings it'll try to go up to 5th or 6th gear at 25 or 30 MPH which is ridiculous. It nearly causes the engine to lug. Seems like the new shift strategy is just not as efficient or smooth as the old one.
In the grand scheme of things I don't care because one of two things is going to happen: I'll get a new truck next year or I'll get the GDE tuning. In either case, my current issues won't last forever.
Yes. It does everything betterI've just assumed that I'd add a throttle controller (probably a Banks) to my truck...once I get it, based on all the "mushy throttle" threads. Does this TSB make the engine respond to the throttle position better?
Ask him if he factored in highway speeds to that wind chill. Then ask him if your warranty will be void if you only drive with a tail wind. He still won’t figure out that you’re ****ing with him.Yeah I'm not a fan. Last time I was there the guy tried to tell me they can deny warranty work for not having my winter cover on. I told him it's not required with the 3rd gen and the owners manual simply states one is available, no where does it mention it's required.
He then tried to me that with wind chill it can be -40 even if it's only -2 out... Well news flash sir, wind chill is only felt by humans.
