K_Hub
- Apr 9, 2020
Are those the newfangled sleeve solder joints I see on Facebook ? You just heat them up and they solder AND shrink? Can you get them locally?
I do regular wiring on machinery and have switched 100% to using the non crimp soldered heat shrink butt connectors. I was super apprehensive when I first got them but spliced a 14 gauge wire, twisted the ends, put the connector in place and shrank it down then hung it in my shop with a 25 lb weight hanging from it. After watching it dangle for 3 days without giving at all I put them to use and will probably never go back to the crimped connectors.
