Eltaco
Finally completed the wiring on my 40” light bar. I now have the DRL option setup and have the option to have the full powered bar to turn on/off automatically with my Hi-beams or disable the light bar for on-road Hi-beam use.
CMil527
Old Bridge, NJ
LOOKS GREAT... DID U HAVE TO FAB UP BRACKETS?
Eltaco
I did make my own brackets. I chose this particular light bar because it has foot mounts which are adjustable along the length of the bar... so I didn’t need to try reach the ends of the 40” bar. This made the fab much more straight forward! Unfortunately, I only have basic handyman tools available, so I had to work with those limitations. You can make this mount with a hacksaw and drill pretty easily.
securityguy
North Florida
Nice job!
mlcarril
Any issues with the sensors? Looks great
Eltaco
No issues. I had to replace that lower grill mesh with an insert from the Diesel 1500, as my Laramie grill is 100% blockage. Everything works exactly as it did from the factory.
I’ve detailed out the process and part numbers in another post on light bars, pods, etc.
Betohemi661
Finally got my maxtrac 2/4 drop installed so far so good
Wakesnowb
I have a 20" light bar and figured it had to stay 20" because of the sensors. Thinking about it, guess there is no reason to not just run a full 40" like you did behind the sensors. Although you had to make your own brackets. Wonder why RC makes the 20" kit but not the 40" kit.
Eltaco
No reason, they just hit the EASY button. :)
Took a bit more measurement to determine fitment before I ordered everything.
My mounting brackets were around $20 including hardware.
The light output of the 40” bar is incredible!
Wakesnowb
Love it. Did you pull the bumper?
Wakesnowb
No need, thankfully. That plastic grill part pops out after removing a few plastic clips and nuts. Once that is out, you have full access to the area.
Cool, I pulled the bumper on mine to make it easier to get all those little plastic clips off. Last question, did you just simply put a bracket on each end of it? Is there anything holding up the middle since it is a rather long light?
Grape_Ape
Really small addition. Bought this cargo net for the truck. Since I have the Ramboxes it was hard to find something that was made for it. So I went with a model that fit the Tacoma. May not use it all that often but for $18 I figured I'd give it a shot.
Three Pocket Pickup Truck Cargo Net Fit for Toyota Tacoma 2013-2019 Cargo Organizer Storage Net https://www.amazon.com/dp/B07JD945LY/ref=cm_sw_r_cp_api_glt_fabc_CSPXQ84N7GMR6JASKN0H
Not the best pictures but you get the idea. For day to day stuff it's easy to keep up if I have any loose stuff I want to keep from bouncing around in the bed that may not fit in the rambox or if it's full.
My mopar tonneau cover latches in a perfect place to hold it in place securely.
  • Top
