K_Hub
- Apr 9, 2020
It's California and everyone loses in California![]()
Unless you’re in the government. They keep winning regardless.
Your member profile display suggests that you’re moving to Texas. Depending on where in Texas, that would kill the issue with ice and slush buildup on the front of the running boards even without the mud flaps. Don’t throw away your ice scraper though. You’ll need that for getting your tires unstuck from the pavement if your Limited sits in one spot for too long on a sunny August day.Installed WeatherTech mud flaps in 18 degree weather today. Thank goodness it was a quick install.
I never cared for the rooster look on the side of my truck, plus I wanted to also protect the TT a bit from rocks when I tow. But the big reason was that I couldn't take the constant mud, slush, and ice getting onto the front half of my power running boards. It gets up there from the spray from the front tires. It wasn't an issue with my fixed steps ony old trucks. Lol. Hopefully this will help lessen the crud that gets on the steps.
Anyways, I can confirm that there is no rub with 34" tires and these mudflaps at full lock.
Below isn't full wheel lock, but it's the closest it gets to the mud flaps (maybe 3/4th inch of space):
And yes, I did clean the areas where the mudflaps were being installed. Had to use a towel soaked in hot water just to keep it from freezing before I could finish. Lol
So, can I assume that you did not install the PPF that came with them to protect the paint around where the mud guards touch?Installed WeatherTech mud flaps in 18 degree weather today. Thank goodness it was a quick install.
Sounds good and understand. That's what I thought based on the cold temps. Just wanted to ensure you knew that it's best to put those on to protect the paint just in caseLol, nope. No way I could have in that cold. I plan to put it on in a couple weeks once it gets above freezing and I can give the truck a proper wash. Luckily it's super easy to uninstall/install the mud flaps.
The catch can is a modification to the emissions system and will definitely fail you on a visual inspection.A lot of people who don’t live in California seem to have very strong opinions about this place and speak authoritatively about it.
A catch can will not make you fail your smog test. I’ve had them on a couple trucks and cars. Never been an issue.
On my Challenger I also had a Mopar K&N air filter set up that came with the car. They gave it a quick look to make sure it had the approval sticker and that was it.
How do you like your Cooper tires? Any road noise?Oh yeah, also did a little dechroming with the new hood badge:
Love those wheels. Those might be at the top of my list but in solid black. Nice choice!On Friday had the Hostile Typhoon H 123 Blade cut wheels installed. I also opted for the less expensive Venom Power XT tires. The before and after are pretty dramatic.View attachment 82119View attachment 82120View attachment 82121View attachment 82122View attachment 82123
Hostile Typhoon 22X10
Venom Power TX Tires 33X12.50
2-inch leveling kit.
Thanks, z0n3, I wanted to go all back but multiple places said there was a two-week delay to get them. In the end, I'm happy I went with the blade cut so I don't have to black out my badges anymore.Love those wheels. Those might be at the top of my list but in solid black. Nice choice!
Nice. What off set is that?Thanks, z0n3, I wanted to go all back but multiple places said there was a two-week delay to get them. In the end, I'm happy I went with the blade cut so I don't have to black out my badges anymore.
love it!On Friday had the Hostile Typhoon H 123 Blade cut wheels installed. I also opted for the less expensive Venom Power XT tires. The before and after are pretty dramatic.View attachment 82119View attachment 82120View attachment 82121View attachment 82122View attachment 82123
