Dusty1948
Very good question. After they installed the new rear window in mine it still leaked. However, there was visible evidence that they missed applying adhesive in a small area just below the third brake lamp assembly. Eventually, to avoid removing the window assembly again, I suggested just that. That worked. Now I did not have a cracked window frame as others have, so just applying adhesive or RTV along the top may not have been a permanent solution. The service tech. and I worked together with the third party glass repair guys to resolve it.So why doesn't one just use a tube of black silicone and fill the gap between the rear window and body then smooth it out with your finger.
Regards,
Dusty
2019 Ram 1500 Billet Silver Laramie Quad Cab 2WD, 5.7 Hemi, 8HP75, 3.21 axle, 33 gallon fuel tank, factory dual exhaust, 18” wheels. Build date: 03 June 2018. Now at: 044609 miles.
