Daverous
- Sep 14, 2020
Keep us postedI just ordered the brake light as I hate current red one . I got an error with 3rd party leds. I really hope it’s plug and play for my 2020 Laramie !
drive.google.com
So I just downloaded AlfaOBD and for now I have the Bafx (waiting for my OBDmx+ To come Sunday). I’ve never used AlfaOBD so how do I upload what you just did? And what are the first steps once I connect the bypass and the obd reader? Sorry I’m a freakin noob lol@Jimmy07
All combined. Haven't used winmerg so not sure if you need it broken up. Doesn't explain a thing about my lack or video but does verify auto dim is down.
DR2020Rebel.txt
drive.google.com
The only thing I see that might have to do with the interior mirror fault is this setting-@Jimmy07
DR2020Rebel.txt
drive.google.com
Also, if it’s the Android version you got, you connect to the BCM, click on the battery icon in the lower right, select read system ID, click on tools up top, select faults and status logs, select body chrysler info, and select upload to google drive.So I just downloaded AlfaOBD and for now I have the Bafx (waiting for my OBDmx+ To come Sunday). I’ve never used AlfaOBD so how do I upload what you just did? And what are the first steps once I connect the bypass and the obd reader? Sorry I’m a freakin noob lol
No, they don’t use anything other than coax cable. Fakra is just a generic term for the keyed plastic connector shell on the end of the coax cable, and it’s color has nothing to do with the function of the cable itself.I'm interested to see if any of you other gents get this going as the parts come in. I'm not set up to individualy test each component other than basic stuff.
Thinking out loud here, but do these Mopar fakra cameras require additional power input other than their display cable? By that I mean when I look up replacement cameras they seem to be a single cable output. I was considering grabbing a power camera side mirror to play with since at some point I'd like to try the 360 as well. I'm just looking for a way to test further without dropping another 800 bucks on the parts I don't need.
Correct, CVPM is only set on vehicles with surround view, or JTs with the integrated front trail cam.I noticed in Daverous’ post with his vehicle config that there is a line that says “full central vision processing present” is set to no. Assuming this doesn’t matter because the cable that connects the camera to the mirror doesn’t run through the CVPM and that would theoretically only be set to “yes” for trucks with surround view?
EDIT: kind of surprised the Rebel with Level 2 and the safety group doesn’t come with the surround view system.
I see this setting in your log- CBC Config I/O Usage: RVDM Present- NOIt clears the faults but so far no luck with reactivation the dimmer. Cycled about 15 times. I'll leave it put and see what happens.
@jdmdc5teg06
Once you download the pc version you can save your current settings as a word document. It's found under the second tab marked status/faults. On the left side click read system ID. It'll make sense when you get in there.
Hit continue. Your 2021 BCM variant isn’t actually supported by AlfaOBD yet, but it will still connect.Jimmy what does this mean?View attachment 78242
By hitting continue, since the BCM isn’t supported yet, would I still be able to change certain things on it like someone would in their ‘19-‘20? And also, would I be able to upload to google so I can show you guys my configurations? Thank you for all your help!!Hit continue. Your 2021 BCM variant isn’t actually supported by AlfaOBD yet, but it will still connect.
Definitely send off the iso so the developer is aware.
Yes. Everything is still the same as far as settings, for the most part.By hitting continue, since the BCM isn’t supported yet, would I still be able to change certain things on it like someone would in their ‘19-‘20? And also, would I be able to upload to google so I can show you guys my configurations? Thank you for all your help!!
