AlfaOBD
Jimmy07
Honorary Site Supporter
Does anybody know if you can adjust the temperature threshold for the auto-on comfort option? I think it’s 40 and 80 by default. But this morning at 48 degrees would have been nice to turn the heater on.
I’m not sure if it can be done or what setting in AlfaOBD IT is. Thanks.
I would like to know this as well....
It can’t be changed
Ryancassidy
So if I'm understanding this.. the 275/65-20 I'm about to put on (2719mm). If I adjust viaa Alpha OBD, parksense may not work?
Anyone successfully done this yet and got both working?
Sorry, just dropped some cash on tires and AlphaOBd and the parts for it.. :)
FishOn
Apologies in advance if this is buried somewhere and I haven't uncovered it yet...
Does anyone have the steps/process for disabling the Active Grill Shutters and the Active Lower Air Dam? Removed all of this and I want to wipe them from the PCM if possible.
CoyoteJosh
Minnesota
Not necessarily. I put on 275/70-18s (~2720mm), after adjusting to get the speed accurate I ended up with 2550mm. This size seems to be within the tolerance and parksense works for me.
wassim
Does anyone know if Alfa OBD will allow Canadian trucks to use only the accent LED lights in the headlights as daytime running lights like the American trucks can do in the settings menu?
I know it’s bit late
But yes I did on my 2019
I disabled DRL completely
Now only led accent are on
snoakes1
Colorado
So, I have been pouring over the Alpha OBD threads. And like a few others I'm still confused. There is so much info out there and after awhile it becomes overwhelming
I'm getting the basic ideas on what to do, but nervous to try. I decided the 1st thing I'm going to try is the Tailgate Ajar setting. I have the Security gateway bypass from Infotainment and the OBDLinkMX+ and using an android Tablet with Alpha... From what I read I can plug the security bypass gateway in and leave it in unless I am taking it to the dealer. Is that correct?
Can somebody give me the specific steps for the Tailgate ajar procedures ? I think after I get one change under my belt I will feel much more confident in the next changes I want to do with the DRL and Fogs. Thank you in advance and I apologize if this is all listed somewhere in a simpler format.
Scott
vincentw56
Scott
I don't know about the tailgate ajar, but the bypass can stay in until you need to take it to the dealer. Mine is in so the time.
Rebelbrand
And that's if they are even capable. My truck came with power-folding mirrors on the window sticker, but then upgraded to the towing package with towing mirrors. I replaced the towing mirrors with standard power-folding mirrors and all the necessary hardware, but my dealer could not add the software to make it work. I had to use Alphaobd, which actually cost less than it would have to get the dealer programming, and I have more power to make other changes now.
If you still have your tow mirrors i would definitely be interested in buying them. My 2500 came with the smaller sport mirror and j caint see around my big utility trailer.
Thedanderzone
Hey all,
This is my first post here but I’ve been browsing the site for awhile now. I got AlfaOBD and have a few questions and a little input as well.
First, I tried to do the stand-alone accent light DRL mod and increase the voltage. However, it doesn’t appear there is a difference for me when I set it at the lowest voltage vs. the highest voltage. I’ve followed the steps in this forum a few times with no luck. I opted to enable the turn signals as my DRLs and I actually quite enjoy that. However, same thing with those as far as the voltage goes - no change (at least visible to my eye.) I haven’t found an option to increase voltage on the turn signals themselves like you supposedly can with the low and high beams.
Second, I tried to enable the mirror turn signal lights as “clearance lights” which also didn’t work the way I was expecting them to. No biggie.
Third, I noticed some posts regarding the tailgate ajar notification and my setting was disabled from factory, which I find odd but not at the same time I guess.
Lastly, I enabled the CHMSL LED bulb present feature and I still get the “no key fob detected” warning, but ONLY when I remote start and go to fully start the truck WITH my foot on the brake. I have Philips ZEVO lights for all my LEDs, including that CHMSL. I have a diode dynamics light on it’s way to hopefully prevent that.
Any other mods I should try? I already disabled the fog light drop out with success! It feels like there is so much more to this app. Eventually I’ll add in the bed lights, probably set the speedo for accuracy when I get new tires, etc.
Thanks!
ccjbmjo
the "Secure Gate Way" Bypass module allows you to use a conventional obd2 transciver to push codes over the network to the body controller. without the bypass, FCA ****ery locks out the end user from being able to fully access the hardware they own.
The SGW installed by FCA actually restricts write access to the bus unless it is unlocked on a per session transaction with FCA computers in corporate. Ways to bypass the SGW are to literally disconnect it and replace with a bypass plug, or to connect directly to the CAN bus before the SGW gets in the way. Before taking it back to the dealer for handling their warranty defects, reinstall their SGW in-line to make them think that their equivalent to a TSA luggage lock is doing its job and they have in fact screwed you out of third party service and repair.
Two things would you have a picture of where the gateway plugs in and also what cable you use (part number etc?)
MeyerzRam
Anyone turn off the eTorque auto on/off using this software?
brian42
San Diego, CA
I have this bypass: https://www.infotainment.com/products/fca-security-gateway-module-bypass?variant=8775773945892
Instead of a BT connection I use this USB cable: https://www.amazon.com/ScanTool-OBDLink-USB-Professional-Diagnostics/dp/B005ZWM0R4
The security gateway is directly behind the parking brake panel:
If you look directly under there with a flashlight you will see the gateway and the 2 plugs you need to disconnect:
The 2 plugs are different sizes so you can't mix up which plug goes into each port.
bobgnarley
West Coast
Thinking of maybe doing a lift and graduating to 35's at some point in the future. Curious to know (attempted searching, but came up short as I often do) – if I were to swap out my factory air bags for a coil setup, would I be able to deactivate the air ride system altogether using this app/interface?
brian42
San Diego, CA
I'm not sure how the air system ties into everything but my BCM has several air suspension options that are not activated:
Air Suspension Control Module (ASCM) has Suspension: No
Air Suspension Control Module (ASCM) has Active Damping: No
Air Suspension Functionality: Not Available
Air Suspension Warning CSM Present: No
ASCM Air Suspension Control Module: Not enabled
ccjbmjo
Would anyone know if the SGW is located in a different location an a 2500? I assume this is a 1500 and mine is not located in this spot.
Jimmy07
Yes, the HDs are located behind the instrument cluster, which has to come out to get to it. You want to use this style bypass, instead-
jabowles82
Has anyone figured out a way to eliminate MDS with alphaobd?
I know the +/- will keep it off, but it would be nice not have to mess with it at all.
