AK103
- Apr 18, 2020
Yes, I’ve had this plugged in for over two months. I know for a fact it’s from a wrecked limited. I’m not sure why this particular module would have to be virgin either. Seems strange, but possible?
Here is my current status in the DASM:
ECU Qualification:
RLS: Not set
AHBM: Not set
HUM: Set
COM: Set
UAM: Set
Theft Deterrent Present: No
Power Locks Present: Yes
Ambient Lighting Present: No
Approach Lamps Present: No
Side Repeaters Present: No
UGDO Theft Disable Present: No
RKE Present: No
Front Fog Lights Present: No
Tip Start Present: No
Remote Start Present: No
Reprogramming Attempt Counter:
Number of Reprogramming Attempts - Block 1: 0
Max. Number of Reprogramming Attempts: Block 1: 1000
Number of Reprogramming Attempts - Block 2: 0
Max. Number of Reprogramming Attempts: Block 2: 1000
VIN Locked: Yes
In-Plant Status: Not active
Sensor Has Been Aligned: Yes
Response on Event - light activation state: Activated
Ignition Voltage: 11.90
FCW Selection: Fcw Near
Blindness Counter: 158
Bussed Outputs:
ACC Set Speed KPH: 0 km/h
ACC Set Speed MPH: 0 MPH
Requested Gear, Upper Limit: 0
HMI Screens: None
Forward collision warning error: FCW Error
Forward collision warning setting: Yes
ACC HMI Screen request: Yes
ACC On/Off Status: Off
Small graphic display: ACC Ready TG1
ACC stop commanded: No
ACC drive off commanded: No
Engine torque request maximum: No
ACC cruise control enabled: No
ACC engaged: No
Status Information DASM: No
Status Information DASM: No fault
Disable fuel shutoff: Yes
Brake jerk request: No
Brakes Pre-Fill Request: No
Assistance system display request (priority): No request
DAS request ID: No assistance system is braking
Forward collision warning status: Not active
Bussed Inputs:
System Voltage: 11.90 V
Averaged Ambient Temperature: -40.00 Deg.C
Vehicle speed: 0.00 km/h
Ignition Switch Status: RUN Position
PRND Status from Trans: Park
Cruise Control Cancel Switch: Not set
ACC Distance Decrease Switch: Not set
SCM Cruise Control Set/Accel Sw: Not set
SCM Cruise Control Coast/Set/Decel Sw: Not set
Cruise Control Resume Switch: Not set
SCM Cruise Control Implausible: Not set
SCM Cruise Control On/Off Sw: Not set
SCM ACC On/Off Sw: Not set
SCM ACC Distance Increase Sw: Not set
ACC Can Be Enabled per ESP: Set
Trans in Limp Home Mode: Not set
Engine Torque Enable Request AS: Enabled
I admire you for tackling this project.
You have way more patience than I do.
