2019 RAM Rebel Lift Kit
jrmitt808
thanks for the confirmation. just put my order in off ebay. good find. a lot cheaper than the other site.
RamRebelSteel
Los Angeles
Dont go more than 2" if u have a rebel/offroad package.
jrmitt808
Also saw this on instagram. Some guy installed the 3.5 lift. I am not a big fan.
ksn240
That is a 4.5" lift over stock without doing anything to correct the cv joint angles or steering angle. I'm surprised if it can even get a proper alignment. If it ever gets put in 4wd something could very easily snap.
jrmitt808
^^ I mentioned that to the installer, and he said "what the customer wants the customer wants". wow.
ksn240
That's crazy. I would hope he explained the risk and advised against it, but if that was his response then I am guessing he didn't.
jrmitt808
I installed the ReadyLIFT 2" Leveling kit with the UCA's. Really only lifts 1.5", but does look much better. I may put the rest of the 3.5" lift on this next summer. View attachment 4452
I liked your setup so much i went with the same setup. btw the Mopar running boards was the easiest install ever. Only issue I had was the way Mopar packages the part. I was missing nuts and bolts, good thing I ended up buying from a Dealership which had some.
mdelikat
Question for Dean V or SWRebel. How’s the ride with the leveling kit? Any noticeable difference.
Timsmxz
Are the new uca really necessary with a leveling kit? Some rebels have the air ride, which can raise the truck up 2" and they use the same uca as a rebel without air ride
VaderRebel
Canada
Do you know for sure the air ride Rebels aren't using the off road/lift kit version of the Mopar UCA? Level your Rebel and then decide once you see your ball joint angle at full droop.
