Glad to finally be able to post in here. 2in RC leveling kit. Method 18x9 -12mm with Falken Widepeak AT3s 305/65r/18
I'm torn between the Method -12 and something else like a Fuel tactic in a zero offset because I also have a truck without fender flares and I don't want too much poke on the sides. You have any pics showing how much they poke out past the fender? Thanks
I've been searching all the threads and there are a few with this same setup, but the pics are hard to figure. Some pics make it look almost flush, but the #'s say they should stick out about an inch. Too bad Method doesn't make a 0ish offset
I have the Fuel Tactics with the +1 offset. (If I remember correctly) 18x9
I can get a better shot this afternoon. But the stick out past the factory Rebel flares a bit.
They poke out about 1-2”. Slightly aggressive but I haven’t noticed any scratches or abrasions from rocks being kicked up.
Thanks for taking time to reply. Definitely some tire showing. Math says they are 31mm (1.22") out from stock 9" wheels. Doesn't sound like much normally, but I think these trucks have factory setups that are already more flush than most trucks. I think I will add some fender flares if I do the method wheels. Another think I have a love-hate feeling about ha ha. Love the offroad tough look of flares, but I picked the clean look of the naked fenders. :)
Sweet truck. The fuel tactic and covert are on my short list. Probably going to do the Falken 285/75 btw.
I can't believe there is only 1/2" difference in offset between your truck and WeeMan16's. Camera angles can be funny.
the Fuel coverts +1 sit flush with my factory fender flares. The poke is from the tire and is about an inch.
Just added some 35x12.5r20 Nitto Ridge Grapplers today to go along with my Combo Readylift 3.5"/Bilstein 5100/5160 Lift which was installed on Monday.
View attachment 60026View attachment 60027
This is the same setup I am looking to do on my 2021. Did you leave the preload spacer off and add the Bilstein on setting 4 or 5? How is the ride?
No preload, Setting #4 ride is similar to stock but so much more composed offroad.
Readylift 2 inch level with control arms, which are getting switched out.
Dirtylife DT-01's 20x9 +12mm offset, beadlock capable wheels with falken wildpeak at3w in 275 60 r20.
Killer truck man!
Did you get the 2 inch foxs or the 2-3 inch version, also how do they ride compared to stock? Did you swap out your control arms also?
Thank you. I love it. The front suspension is a 2.” Rear shocks didn’t add any lift but I have the ORG springs. These Fox shocks were super expensive and it rides so much better than stock as it darn well should lol! Seriously though, hats off to Fox. My previous 5th gen had a ReadyLift leveling kit and honestly it rode like garbage. But it’s a spacer. There is no comparison. And yeah I did swap out the UCA’s with BDS UCA’s.
edit: I did see you have a ReadyLift level so I hope I didn’t offend you.
That looks awesome. Are those rims matte black double tinted ?
Also are you running 2” Mopar lift, and what size of tires ?
Thanks.
Maybe I'm missing something but all of those questions can be answered by simply reading the information in his signature.
I was looking for his signature before I asked, but it’s not showing in here.
Thanks man. Here you go:
2020 BTS, Ceramic Gray, Crew Cab, 6.4 Bed, 4X4, 5.7 Hemi V8 w/ eTorque, Level 2, 3.92, Trailer Tow Group, 33 gallon tank, pano sunroof, Fox 2.5 coilovers, Fox 2.0 rear shocks, ORG rear springs, 18x9 Fuel Vector gun metal wheels 0 offset, 35/11.5/18 Falken Wildpeak A/T tires, tinted front windows
Haha no offense taken! The readylifts were the only thing out at the time I bought them so.
I'm looking to switch them out for total choas or icon UCA's pretty soon and swap in the 2/3 inch fox shocks to.
