Finally!!! I just picked up my truck today and is it everything I wanted. I am hoping to get some good pictures this weekend to post, but here is all I have for now after picking it up this afternoon. 4" BDS Suspension lift with Fox 2.0 shocks in the rear, factory shocks in the front. Will update to Fox once they become available. 20 x 10 with a -18mm offset Fuel Beast Rims with Nitto 35" x 11.50" Ridge Grapplers. After 55 miles, I have to say the ride is AWESOME and is every bit as good as my factory ride was. I am very impressed and pleased. Tires seem to only have the sidewall and a touch of the tread sticking out of the fenders. PERFECT for me.
4” lift with stock shocks? That must be a massive spacer?
edit : I see it’s a whole new setup.
looks pretty good.
Nice, so you’re selling those 22” wheels / tires then correct ?
I have them and I am not sure what I should do with them because I will probably never use them. There are 300 miles on them and they were ceramic coated when I had the truck done. Then I took them off and had the Black 20" Longhorn Rims on that I bought because I was not sure I wanted 22" wheels & tires. Now I have 3 set of rims and tires with the new Fuel rims & tires I put on with the lift, lol. More $ that brains I guess. So I may just part with my 22" factory rims & tires because I honestly don't think I will use them at this point.
Honestly I’m not even sure if you’ll be able to use those oem wheels unless you add a spacer. Now I could be wrong but it’s always good to check.
Stock 20s
3.5 up front 1 inch in back
I like the way that lift/tire/wheel combo came out :) Can you ballpark the cost for me?
Not only can I ballpark it, I can give you the exact breakdown:
BDS 4" Lift kit w/ Fox Shocks & shock boots - $2450
Nitto RG's & Fuel Beast Wheels w/ TPM's - $2865
Alignment - $149.95
Labor - $840
NYST - $515
Total OTD - $6820
Pretty steep cost in my book, BUT, it is EVERYTHING I wanted as far as the look and ESPECIALLY the ride so given that I am VERY happy with the end result, it makes the pain of dropping so much $ a little easier to take.
Glad to finally be able to post in here. 2in RC leveling kit. Method 18x9 -12mm with Falken Widepeak AT3s 305/65r/18
Mark,
Any rubbing with the 35? Im going to #7 with 2" spacers on stock wheels
Sorry for the late response but the only rubbing I had was due to a plastic inner fender next to the frame, just screw it to the frame and you’re good to go, post some pics when you get it done
