MopaRAMan
- Sep 5, 2018
Oddly, my truck hasn't made the clunk for a couple weeks now. Over the first couple weeks I heard it half a dozen times. To me it sounded and felt like the bottom of a metal gas can that pops when it cools down at the end of the day.
For those that hear it often, will driving over an uneven surface very slowly at an angle produce the thunk?
Thinking about the possibility that the no load isolator is by design, this frame could flex quite a bit and then stiffen back up quickly. If the body mount on the cab isn't reinforced properly, the frame could be pulling down on the cab which could create a senerio similar to the bottom of a gas can popping back to the relaxed state after the weight of the frame releases tension on the body. It could be the mount isolator has too little free play or the cab has too little reinforcement around the mount. If it happens when there is very slow movement of the cab, that would potentially point to the possibility that stored energy was released at once verse the cab slamming back down. Sound plausible to anyone?
