Grinding noise when turning to the right
RamCares
Michigan
My dealer is willing but they will need an OK. Right now they won’t do anything because FCA says there is no real fix for it.
Thank you for the response. I kindly recommend submitting your information at https://www.ramtrucks.com/webselfservice/ram/emailpage.html to receive a follow up from a specialist on this concern so that they can assist with next best steps based on your last dealer visit.
I am having the same issue with my 19 Ram Laramie, grinds when making slow right hand turns, I thought either tires or something in the power steering or rack and pinion. Have a service appointment in a couple weeks.
Hi @josh_4184 - If you would be interested in an additional layer of support while working with your dealer, we are more than willing to get you connected with a specialist for further support through that process. Please do not hesitate to follow up with us via private message.
Mark
RamCares
Yanni123
Having same issue, dropped off at dealership yesterday. Today they say it's a problem and say FCA cannot fix at this time, I should go pick up my truck and wait for a fix. Never dealt with something like this before, should I pick up my truck with the issue still and wait for the official fix?
Thanks!
RamCares
Michigan
Thanks!
I regret to hear that you are also experiencing this concern, @Yanni123. If it would be of interest, I would be more than willing to escalate a case on your behalf so that this is on record and you can discuss your situation further with a customer care specialist. You may call in at 866-726-4636 or submit your info here to receive an email follow up. https://bit.ly/3fy5Kfo
Mark
RamCares
gibbynd
Mark
RamCares
Well FCA wrote me back. Said i already had a case opened on this issue and since there is no fix like they stated before they seen closing it. It is up to me to work with my dealer on an appropriate fix
speedracernc
I have the same problem and was told the same by the dealer. Seems like this is a common problem. Hopefully they find a fix soon.
I would be interested to know how many people noticed resolution of the problem after changing tires.
ya3coub
Doha - Qatar
Hi @Beddow05 & @FL Laramie,
Please do not hesitate to follow up with us via private message if you have any interest in an additional layer of support while addressing this with your dealers. I am happy to escalate cases for you which will provide the dealership and yourself with an individual who will review your concern, then assist you and the dealership in exhausting all available resources to have the concern addressed and resolved.
Mark
RamCares
Will you be able to do this with international dealers??
I have the exact thing and every service i take my car i complain about it and they keep telling me its normal
RamCares
Michigan
Unfortunately our team here is only able to work with customers located in the United States. You can find the team in your region by visiting https://mideast.mopar.com/en/customer_care.php.
Mark
RamCares
Jeremiah2020
Hi @Hazzie & @Noobman - Please know that we are more than happy to provide you with an additional layer of support if you move forward with addressing this with your dealers. We would like to escalate your situations to a Case Manager which will provide the dealership and yourself with an individual who will review your concern, then assist you and the dealership in exhausting all available resources to have the concern addressed and resolved.
Please follow up with us via private message when you can!
Mark
RamCares
I have the same issue and my truck has been in now to service with a case number from Ram just to be told it was a ground issue and that there was a bulletin out for it. They corrected said ground issue and said that should take care of problem, needless to say nothing changed. I just bought this a week ago at 32k and now at 33k with my basic warranty about to expire. I can't believe I'm having this type of an issue from a 2019 so called CPO with only 33k on it. Once I got 35k I was told the issue is on me cost wise since the so called warranty expires. So far not a fan of Ram's care or CPO very disappointed in this.
RunsWithBeer
NC
Reading through the thread, I'm wondering if the issue is similar to one we had with our Chrysler T&C. I listened to the recordings of the noise and it was identical to the noise in our van.
In my case it was a malfunction of the anti lock brake module that would occur when accelerating from sharp right or left hand turns. The sound was identical to the buzzing/grinding noise posted.
In our case the dealership and independent mechanics never figured it out. It was out of warranty when it occurred and the dealership charged me $500 to replace parts that didn't fix it. In our case, after the noise there would be a loss of brakes until the vehicle was restarted. It was very random and scared my wife to the point she stopped driving the van.
The issue went away after I replaced the battery. Whether the electrical system simply needed a reset or the battery voltage from the old battery was too low to effectively operate the ABS, I do not know.
Turning sharply does cause the wheel speed sensors to report different speeds to the ABS controller, so there is a relationship there.
Just a thought.
syddog 2000
I had the same issue also. Took it to my local dealer, not where I purchased the truck they had the truck for 4 days. Returned the vehicle said they could not replicate the issue. I have never had any luck at that dealer. I recently went to my purchasing dealer. They took the time and determined the rack needed replacement. Done under warranty has been two months since and all is good. Find a good dealer and service department.
Charon
I'd say if that did work it's probably just a bandaid because it changes the ride it might cover it up until it gets worse. The real issue is in the rack as many people have experienced.
FL Laramie
I had the rack replaced 4k miles ago. The vibration/grinding was gone. Unfortunately, it has come back on right hand turns. Same vibration.
RamCares
Michigan
I am deeply sorry for the frustration, @Jeremiah2020. Please do not hesitate to send over your case number via private message so that I may look into your situation further on my end.
Hi @FL Laramie - I regret to hear this update. If you plan to move forward with your dealer on this, please be sure to let us know.
Mark
RamCares
gibbynd
Mark
RamCares
We can’t move forward with our dealers because FCA is not providing a fix. They won’t do anything unless there is a TSB
Fixedwing17
I have the same issue. The most asinine thing about this is not the problem itself, but the fact that a company who has been building trucks for decades doesn’t know how to fix it. Unacceptable.
janno_napster
Same issue here just happen like 2 weeks ago from time to time...its weird just happen in like a sec then gone..only happens when turning the steering wheel to right and in a slow speed like 5-10km
RunsWithBeer
NC
Is the frequency (pitch) of the vibration constant, or does it vary with speed while you are turning?
