Mine did the same thing at low speed. Dealer replaced the rack@pinion and fixed the issueHi, My truck have a grinding noise when turning to the right. The noise coming from the steering area. Someone here with the same problem.
When you turn to the right the noise coming from steering area? Are you hear strange rattle in bumps behind the steering?Mine did the same thing at low speed. Dealer replaced the rack@pinion and fixed the issue
The Grinding noise you hear when turning to the right coming from outside or inside ?When you turn to the right the noise coming from steering area? Are you hear strange rattle in bumps behind the steering?
No rattles over bumps. Sound came from the steering column and only happened when turning right in certain situations and at low speedThe Grinding noise you hear when turning to the right coming from outside or inside ?
Did you ever get this fixed ? If so what was the problem ?No rattles over bumps. Sound came from the steering column and only happened when turning right in certain situations and at low speed
Yes it was resolved. Dealer replaced the rack & pinion.Did you ever get this fixed ? If so what was the problem ?
Mine started at about 10k miles. Same issue as you. Feel a vibration in the steering column similar to the tires grinding on a plastic wheel well cover. At 20k service, the dealer said they couldn't replicate the problem. Same as the 30k. Whatever it is has slowly lessened now that I'm at 30k. There's a similar post where someone showed pics of the steering knuckle and control arm rubbing. Not sure if this is normal but mine is the same. Taking the truck to the dealer for this again. Good luck.
Exact same thing as mine... making a 45 degree right hand turn at ~15 MPH will generate this feeling from steering column (sounds as if it is from the left front wheel).No rattles over bumps. Sound came from the steering column and only happened when turning right in certain situations and at low speed
Will be taking it into dealership soon.
I have the same exact issue with my 2019 Limited 1500 40k miles
@RamCares is this something covered under warranty? Hope I didn't miss the boat at 40k miles...
Hi @Hazzie & @Noobman - Please know that we are more than happy to provide you with an additional layer of support if you move forward with addressing this with your dealers. We would like to escalate your situations to a Case Manager which will provide the dealership and yourself with an individual who will review your concern, then assist you and the dealership in exhausting all available resources to have the concern addressed and resolved.
Please follow up with us via private message when you can!
Mark
RamCares
Hi @Razilla76 - Would you mind following up with me via PM to provide further details regarding your most recent dealer experinence? I would like to learn more to determine how to best assist at this point.I’ve been into the dealer twice for this same issue. I feel a grinding noise in the steering wheel when making a right turn at low speed between 8-10 mph. The dealer has not been able to reproduce the issue both times the truck has been taken in. My truck was built February 2019 and the TSB 19-002-18 lists trucks built between August 3, 2018 and August 28, 2018.
What more can I do so the dealer will fix the issue. Is there an updated TSB for this issue?
Hi @Douglas31 - I apologize that you are also experiencing this. If it would be of interest, I am more than happy to escalate a case on your behalf so that a specialist can work alongside your dealer for this concern.My 2020 Limited does the same thing. I plan to have it addressed soon. Not surprised to have steering concerns since my 2019 had steering problems as well but not the same. This makes two 5th gens with multiple issues for me. Pretty frustrating.
Same issue on my 2019 Limited. Dealer couldn't replicate it two earlier times, this time I'm going to ride with someone till they hear it.
